cgal-discuss - Re: [cgal-discuss] Nef Polyhedra test cases
  • To:
  • Subject: Re: [cgal-discuss] Nef Polyhedra test cases
  • Date: Mon, 07 Jan 2008 13:11:05 +0100
Hi Gilbert,
half an hour is more than I would expect from a model of that size. I
have an example file that has about 2/3 of the size of your model and
the execution of handling_double_coordinates takes less than half a
minute. So, I'm a bit surprised. Can you please send me the file so that
I can test it.
Peter
On Mon, 2008-01-07 at 03:47 -0600, Gilbert Bernstein wrote:
> It seems I have to apologize for making such a stink here. It was
> probably a false alarm.
> I think I had unreasonable expectations on the speed of the
> computation and thought the program had gone into a loop. I managed
> to push a smaller model (3756 vertices 7512 triangles) through the
> conversion both ways just now by waiting about half an hour. I also
> know the model in question has some very funky joins between parts
> (lots of long, close, sharp polygons) so I'm pretty sure this was
> just a matter of patience. If only I was testing with the teapot.
> Then I could make a really awful joke about watched teapots.
> I just ran another model (1007 vert 2010 tri) through just fine, much
> faster, so yeah...
> -- Gilbert
> On Jan 7, 2008, at 3:12 AM, Andreas Fabri wrote:
> Gilbert,
> It might be the best to just post a file that makes problems.
> What is your OS/compiler, did you just take the example or
> demo program, or write your own program? In the latter case
> what kernel did you chooses?
> andreas
> > Andreas,
> > I'm fairly sure all of the meshes I've tried are triangular
> > meshes, (I went back and checked a couple of them (since they're in
> > ascii) by eye) so I don't think that's the problem.
> > -- Gilbert
> > On Jan 7, 2008, at 2:10 AM, Andreas Fabri wrote:
> > Hello,
> > A typical problem is to have faces which are not triangular,
> > and at the same time not coplanar.
> > andreas
> >> Hi,
> >> I'm having an awful lot of trouble successfully building Nef
> >> Polyhedra from .off input files. The only model I have
> >> successfully translated from .off to a Nef Polyhedron and back is
> >> a cube. I have tried a number of different models, all supposed
> >> to be watertight, and which were certified by the
> >> Polyhedron_3::is_closed() function. It certainly may be the case
> >> that there was something off (ba dum chh) about these models, but
> >> I've reached my point of frustration. If anyone has any known
> >> working examples of importing models into the Nef Polyhedron type,
> >> or any suggestions, I would much appreciate the tips.
> >> -- Gilbert Bernstein
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://lists-sop.inria.fr/wws/info/cgal-discuss
