cgal-discuss - Re: [cgal-discuss] Nef Polyhedra test cases
  • To:
  • Subject: Re: [cgal-discuss] Nef Polyhedra test cases
  • Date: Tue, 8 Jan 2008 18:28:10 -0600
  • Domainkey-signature: s=main; d=mail.utexas.edu; c=nofws; q=dns; h=Received:Received:Received:Mime-Version:In-Reply-To: References:Content-Type:Message-Id: Content-Transfer-Encoding:From:Subject:Date:To: X-Mailer; b=aM3Ax9yAteqflUlVOFWyQDSk3Vz5qOQ2HiMAuN6jH0FBLoP61wk51 5zqdGS6MB1dSJbs5EQDCGM6QWxv9z460ETVIT+4FDzy9pEmaI93mG muxefVHBpuy77dH7AlHhU/xnydGt/Kkgdi7s6XaE3iTjZQm9M26hh H85B52jXpK6c=;
In fact, I don't have Gmp. I'm working on downloading it now. Should I grab any of the other arithmetic libraries in order to get good performance or correct behavior out of the Nef Polyhedra code?
-- Gilbert
On Jan 8, 2008, at 6:03 AM, Peter Hachenberger wrote:
So, the robocat took less than 20 seconds on my notebook, which has 2
Ghz with only one Core. So, taking also your other mail into accout, it
seems that your CGAL installation might miss some important data types
and is therefore slower than necessary. Maybe the code I gave you in the
previous mail will not compile, because you don't have Gmp or some
similar problem.
Peter
On Mon, 2008-01-07 at 13:46 -0600, Gilbert Bernstein wrote:
Peter,
Here is the robocat (3756 vert 7512 tri) model, which I was able to
get through in half an hour. I was running another job along with
it, so it may not take that long, though it should take a good while.
I also tried a simplified shark model (1007 vert 2010 tri) which I
just measured at appx. 2 min to convert on my 1.83 Ghz Core Duo (not
Core2) (using only one core I believe)
-- Gilbert
On Jan 7, 2008, at 6:11 AM, Peter Hachenberger wrote:
Hi Gilbert,
half an hour is more than I would expect from a model of that size. I
have an example file that has about 2/3 of the size of your model and
the execution of handling_double_coordinates takes less than half a
minute. So, I'm a bit surprised. Can you please send me the file so that
I can test it.
Peter
On Mon, 2008-01-07 at 03:47 -0600, Gilbert Bernstein wrote:
It seems I have to apologize for making such a stink here. It was
probably a false alarm.
I think I had unreasonable expectations on the speed of the
computation and thought the program had gone into a loop. I managed
to push a smaller model (3756 vertices 7512 triangles) through the
conversion both ways just now by waiting about half an hour. I also
know the model in question has some very funky joins between parts
(lots of long, close, sharp polygons) so I'm pretty sure this was
just a matter of patience. If only I was testing with the teapot.
Then I could make a really awful joke about watched teapots.
I just ran another model (1007 vert 2010 tri) through just fine, much
faster, so yeah...
-- Gilbert
On Jan 7, 2008, at 3:12 AM, Andreas Fabri wrote:
Gilbert,
It might be the best to just post a file that makes problems.
What is your OS/compiler, did you just take the example or
demo program, or write your own program? In the latter case
what kernel did you chooses?
andreas
Andreas,
I'm fairly sure all of the meshes I've tried are triangular
meshes, (I went back and checked a couple of them (since they're in
ascii) by eye) so I don't think that's the problem.
-- Gilbert
On Jan 7, 2008, at 2:10 AM, Andreas Fabri wrote:
Hello,
A typical problem is to have faces which are not triangular,
and at the same time not coplanar.
andreas
Hi,
I'm having an awful lot of trouble successfully building Nef
Polyhedra from .off input files. The only model I have
successfully translated from .off to a Nef Polyhedron and back is
a cube. I have tried a number of different models, all supposed
to be watertight, and which were certified by the
Polyhedron_3::is_closed() function. It certainly may be the case
that there was something off (ba dum chh) about these models, but
I've reached my point of frustration. If anyone has any known
working examples of importing models into the Nef Polyhedron type,
or any suggestions, I would much appreciate the tips.
-- Gilbert Bernstein
