- To: "" <>
- Subject: Re: [cgal-discuss] Nef Polyhedra test cases
- Date: Mon, 7 Jan 2008 14:01:16 +0800
- Disposition-notification-to: "LoadCom" <>
- Organization: LoadCom
Hello Gilbert Bernstein
I also came aross lots of problems playing with Nef.
It seems that I'm more fortunate. I've tested
constructing more complex models than a cube or a
tetrahedron. And I'd like to share one of my models
with you. See nef.off as attached.
The other file is the visualization of the polyhedron.
Good luck!
B/Rgds
Max
----- Original Message ----
To:
Sent: 2008-01-07 13:37:31
Subject: [cgal-discuss] Nef Polyhedra test cases
Hi,
I'm having an awful lot of trouble successfully building Nef
Polyhedra from .off input files. The only model I have successfully
translated from .off to a Nef Polyhedron and back is a cube. I have
tried a number of different models, all supposed to be watertight,
and which were certified by the Polyhedron_3::is_closed() function.
It certainly may be the case that there was something off (ba dum
chh) about these models, but I've reached my point of frustration.
If anyone has any known working examples of importing models into the
Nef Polyhedron type, or any suggestions, I would much appreciate the
tips.
-- Gilbert Bernstein
nef.off
Description: Binary data
- Nef Polyhedra test cases, Gilbert Bernstein, 01/07/2008
- Re: [cgal-discuss] Nef Polyhedra test cases, LoadCom, 01/07/2008
- Re: [cgal-discuss] Nef Polyhedra test cases, Andreas Fabri, 01/07/2008
- Re: [cgal-discuss] Nef Polyhedra test cases, Gilbert Bernstein, 01/07/2008
- Re: [cgal-discuss] Nef Polyhedra test cases, Peter Hachenberger, 01/07/2008
- Re: [cgal-discuss] Nef Polyhedra test cases, Peter Hachenberger, 01/08/2008
- Re: [cgal-discuss] Nef Polyhedra test cases, Gilbert Bernstein, 01/09/2008
