- To:
- Subject: Re: [cgal-discuss] Linker errors in CGAL 3.4 examples?
- Date: Tue, 10 Mar 2009 13:24:42 -0200
Hi Tom,
Hi Fernando,
Yes, like written earlyer, I do :)P:\Program Files (x86)\CGAL-3.4>cmake .^^^^^^^^^^^^^^^^^^^^
So you have a 64-bits Windows, right?
OK
Did you try with the 32-bits or 64-bits gmp libs?
I only have the libs provided with the installer. I don't know if they
are 32- or 64-bit.
Within the components selection page in installer, at the very right, there is a ratio button with 32 and 64 bits choices.
That indicates which precompiled libs is downloaded.
The default is 32-bits so I suppose that what you downloaded.
Should I compile them by myself (I read it could get
complicated with this)?
You'll probably need to.. but let's try one more time with the precompiled libs.
>And did you try with the 32 or 64 bits Configuration in the VS IDE?
There is only a Win32 target in the created solution and project files.OK, so I guess you are using the correct 32-bit libs nevertheless.
So I guess I tryed only 32 bits, currently I found no way to create
another target.
Btw, have you installed SP1 for Visual Studio 2008?
We did, and those libs where produced with a patched VS. Could this be the problem?
HTH
Fernando Cacciola
www.geometryfactory.com
Thanks,
Tom
No virus found in this incoming message.
Checked by AVG - www.avg.com Version: 8.0.237 / Virus Database: 270.11.9/1993 - Release Date: 03/10/09 07:19:00
- Re: [cgal-discuss] Linker errors in CGAL 3.4 examples?, (continued)
- Re: [cgal-discuss] Linker errors in CGAL 3.4 examples?, Fernando Cacciola, 03/05/2009
- Re: [cgal-discuss] Linker errors in CGAL 3.4 examples?, Tom Kazimiers, 03/05/2009
- Re: [cgal-discuss] Linker errors in CGAL 3.4 examples?, Tom Kazimiers, 03/06/2009
- Re: [cgal-discuss] Linker errors in CGAL 3.4 examples?, Tom Kazimiers, 03/07/2009
- Re: [cgal-discuss] Linker errors in CGAL 3.4 examples?, Mahmood Naderan, 03/08/2009
- Re: [cgal-discuss] Linker errors in CGAL 3.4 examples?, Tom Kazimiers, 03/08/2009
- Re: [cgal-discuss] Linker errors in CGAL 3.4 examples?, Fernando Cacciola, 03/09/2009
- Re: [cgal-discuss] Linker errors in CGAL 3.4 examples?, Tom Kazimiers, 03/10/2009
- Re: [cgal-discuss] Linker errors in CGAL 3.4 examples?, Fernando Cacciola, 03/10/2009
- Re: [cgal-discuss] Jet_fitting_3, Priyamvad Deshmukh, 03/05/2009
- [cgal-discuss] Triangulation of a Polygon_with_holes_2 without introducing Steiner points, BBB HHH, 03/05/2009
- Re: [cgal-discuss] Triangulation of a Polygon_with_holes_2 without introducing Steiner points, Laurent Rineau (GeometryFactory), 03/05/2009
- Re : [cgal-discuss] Triangulation of a Polygon_with_holes_2 without introducing Steiner points, BBB HHH, 03/05/2009
- Re: [cgal-discuss] Jet_fitting_3, Priyamvad Deshmukh, 03/06/2009
- Re: [cgal-discuss] Jet_fitting_3, Marc Pouget, 03/08/2009
