cgal-discuss - Re: Re: Re: Re: Re: [cgal-discuss] Re: How to use CGAL Trang methods
  • To:
  • Subject: Re: Re: Re: Re: Re: [cgal-discuss] Re: How to use CGAL Trang methods
  • Date: Tue, 13 Mar 2012 23:15:28 +0300
I have re-installed CGAl but this time it is giving this message in CMake:
CMake Error at C:/Program Files (x86)/CMake 2.8/share/cmake-2.8/Modules/CMakeTestCCompiler.cmake:52 (MESSAGE):
The C compiler "cl" is not able to compile a simple test program.
It fails with the following output:
Change Dir: C:/Program Files (x86)/CGAL-3.9/CMakeFiles/CMakeTmp
Run Build Command:C:\Windows\Microsoft.NET\Framework\v4.0.30319\MSBuild.exe
cmTryCompileExec.vcxproj /p:Configuration=Debug
Please help . Am really stuck :(
On 13 March 2012 20:02, Laurent Rineau (GeometryFactory) <> wrote:
Le mardi 13 mars 2012 19:54:27 Sweety Pie a écrit :
> Thank you very much for this. Your help is appreciated. This CGAL is
> driving me Crazy :(
> Somehow the CGAL folder has just disappeared from my  disc and I don't know
> how!!!!!
> Am installing CGAL 3.9 again but I wanted to know something. I have done
> the installation a bit while ago so just to double check. Am using Win7 x64
> bit machine so when I install CGAL if I choose the 32 bit option is it
> going to work fine? since the boost thingy won't trouble me if I choose 32.
That is all right. You can compile 32 bits programs on a x64 Windows. Make
sure you do install or compile 32 bits binaries of all dependencies.
Laurent Rineau, PhD
R&D Engineer at GeometryFactory           http://www.geometryfactory.com/
Release Manager of the CGAL Project       http://www.cgal.org/
