cgal-discuss - Re: Re: Re: Re: [cgal-discuss] Re: How to use CGAL Trang methods
  • To:
  • Subject: Re: Re: Re: Re: [cgal-discuss] Re: How to use CGAL Trang methods
  • Date: Tue, 13 Mar 2012 19:54:27 +0300
Thank you very much for this. Your help is appreciated. This CGAL is driving me Crazy :(
Somehow the CGAL folder has just disappeared from my  disc and I don't know how!!!!!
Am installing CGAL 3.9 again but I wanted to know something. I have done the installation a bit while ago so just to double check. Am using Win7 x64 bit machine so when I install CGAL if I choose the 32 bit option is it going to work fine? since the boost thingy won't trouble me if I choose 32. Please advice.
Thx
On 13 March 2012 13:11, Laurent Rineau (GeometryFactory) <> wrote:
Le lundi 12 mars 2012 21:11:17 Sweety Pie a écrit :
> The GNU is for the Zlib thing to uncompress the files.
> I will send you the txt file .Thank you very much for the help
> Regards,
Do not use ZLib from GnuWin32. It seems to cause a lot of compilation issues
(see that Google search: http://bit.ly/y5Psb3 ). I prefer not to try
understanding the reasons.
Use Zlib from the upstream project zlib.net. There are precompiled versions
available, at least for i686. For example:
 http://www.winimage.com/zLibDll/index.html
Not tested. I compiled zlib myself from the sources given by zlib.net.
Laurent Rineau, PhD
R&D Engineer at GeometryFactory           http://www.geometryfactory.com/
Release Manager of the CGAL Project       http://www.cgal.org/
