- To:
- Subject: [cgal-discuss] How to use the examples of CGAL
- Date: Thu, 12 Apr 2012 19:11:34 -0700 (PDT)
I am not sure if I intall the cgal correctly, because there isn't a "bin"
file under the cgal installed directory.
http://cgal-discuss.949826.n4.nabble.com/file/n4553639/22.bmp
However, I can use the cmake configure and generate the cgal successfully.
Then, when I build an empty project to run the cgal example width_simplex,
there are lots errors such as
http://cgal-discuss.949826.n4.nabble.com/file/n4553639/6.bmp
Are there anything needed to set? *How to use the example of cgal step by
step*? There is a file named CMakeLists with width_simplex.cpp file under
the directory C:\Program Files\CGAL-4.0\examples\Width_3. Is it helpful? How
to use? My installed softwares versions are CGAL-4.0, CMake 2.8, boost_1_47,
Qt4.8.1, and vs2010.
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/How-to-use-the-examples-of-CGAL-tp4553639p4553639.html
- [cgal-discuss] How to use the examples of CGAL, daisy, 04/13/2012
- <Possible follow-up(s)>
- [cgal-discuss] Re: How to use the examples of CGAL, daisy, 04/13/2012
- Re: [cgal-discuss] Re: How to use the examples of CGAL, Laurent Rineau (GeometryFactory), 04/13/2012
- [cgal-discuss] Re: How to use the examples of CGAL, daisy, 04/14/2012
- Re: [cgal-discuss] Re: How to use the examples of CGAL, Philipp Moeller, 04/14/2012
