- To:
- Subject: [cgal-discuss] Re: How to use the examples of CGAL
- Date: Fri, 13 Apr 2012 07:05:11 -0700 (PDT)
Maybe you are right. There isn't any dll files next to lib files under the
boost installed directory /C:\Program Files\boost\boost_1_47/
http://cgal-discuss.949826.n4.nabble.com/file/n4554927/111.bmp
But I launched the boost_1_47_setup.exe again and again, three times. And
every time it showed that the boost has installed successfully. I want to
try to find the dll files from compressed boost and copy them to my boost
installed directory, do you think is it useful? Or if I uninstall the boost
and install again, should I install cgal again?
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/How-to-use-the-examples-of-CGAL-tp4553639p4554927.html
- [cgal-discuss] How to use the examples of CGAL, daisy, 04/13/2012
- <Possible follow-up(s)>
- [cgal-discuss] Re: How to use the examples of CGAL, daisy, 04/13/2012
- Re: [cgal-discuss] Re: How to use the examples of CGAL, Laurent Rineau (GeometryFactory), 04/13/2012
- [cgal-discuss] Re: How to use the examples of CGAL, daisy, 04/14/2012
- Re: [cgal-discuss] Re: How to use the examples of CGAL, Philipp Moeller, 04/14/2012
