cgal-discuss - Re: [cgal-discuss] Re: How to use the examples of CGAL
  • To:
  • Subject: Re: [cgal-discuss] Re: How to use the examples of CGAL
  • Date: Fri, 13 Apr 2012 11:02:52 +0200
Le vendredi 13 avril 2012 01:52:23 daisy a écrit :
> I use Cmake build all the examples of CGAL by setting the variable
> WITH_examples=ON when configure and generate. And bin file is generated
> under the cgal installed directory. There are also more files under the
> directory C:\Program Files\CGAL-4.0\examples\Width_3. However, when I open
> the project Width_3_example.sln by vs2010, there's only one warnning without
> any error when I build solution. But when I try to debugging or start
> without debugging, error happens:
> http://cgal-discuss.949826.n4.nabble.com/file/n4554192/%E6%89%BE%E4%B8%8D%E5
> %88%B0ALL_BUILD%E2%80%94%E2%80%941.bmp So, what's the matter?
The ALL_BUILD vcproj does not create a program. You cannot launch it. But in
examples/Width_3/, you should be able to launch width_simplex.exe
Laurent Rineau, PhD
