cgal-discuss - [cgal-discuss] Re: How to use the examples of CGAL
  • To:
  • Subject: [cgal-discuss] Re: How to use the examples of CGAL
  • Date: Fri, 13 Apr 2012 08:05:57 -0700 (PDT)
Hi,
I finally find the file boost_thread-vc100-mt-gd-1_47.dll under the
boost installed directory C:\Program Files\boost\boost_1_47. And according
to your suggestion, I put it in the debug file where the .exe file is. And I
successfully launch the width_simplex.exe.
(It seems that setting PATH enviornment doesn't work.)Thank you a lot. But I
have another question that if I want to add or modify some codes to the file
width_simplex.cpp, when I configure and generate the examples again, does
the example's output change with to my modification?
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/How-to-use-the-examples-of-CGAL-tp4553639p4555106.html
