- To:
- Subject: Re: [cgal-discuss] Re: How to use the examples of CGAL
- Date: Fri, 13 Apr 2012 15:20:56 +0200
Le vendredi 13 avril 2012 05:59:59 daisy a écrit :
> I tried. But when I launched the width_simplex.exe under the directory
> *C:\Program Files\CGAL-4.0\examples\Width_3\Debug*, error happend: /unable
> to find CGAL-vc100-mt-gd-4.0.dll/,then I found the file both under the
> directory *C:\Program Files\CGAL-4.0\bin* and under *C:\Program
> Files\CGAL-4.0\bin\Debug*, so I copy the later one and paste it to the
> *C:\Program Files\CGAL-4.0\examples\Width_3\Debug*. However, when I launched
> the width_simplex.exe again, error happend again: unable to find
> boost_thread-vc100-mt-gd-1_47.dll/. It didn't show me where I should find
> the file. This time I couldn't find the very file either under the directory
> C:\Program Files\CGAL-4.0 or C:\Program Files\boost\boost_1_47. In a word,
> I failed to launch the width_simplex.exe. Worsemore, I can't find the
> reason. I doubt if I lack of some dll files or failed to set something.
As said in the Installation manual of CGAL, the directories containing the
CGAL DLLs and Boost DLLs must be in the PATH environment variable. Or you
must
copy those DLLs to C:\Windows\, or inside the directory of the .exe file that
depends on those DLLs.
Laurent Rineau, PhD
- [cgal-discuss] How to use the examples of CGAL, daisy, 04/13/2012
- <Possible follow-up(s)>
- [cgal-discuss] Re: How to use the examples of CGAL, daisy, 04/13/2012
- Re: [cgal-discuss] Re: How to use the examples of CGAL, Laurent Rineau (GeometryFactory), 04/13/2012
- [cgal-discuss] Re: How to use the examples of CGAL, daisy, 04/14/2012
- Re: [cgal-discuss] Re: How to use the examples of CGAL, Philipp Moeller, 04/14/2012
