- To:
- Subject: [cgal-discuss] Re: How to use the examples of CGAL
- Date: Fri, 13 Apr 2012 01:52:23 -0700 (PDT)
I use Cmake build all the examples of CGAL by setting the variable
WITH_examples=ON when configure and generate. And bin file is generated
under the cgal installed directory. There are also more files under the
directory C:\Program Files\CGAL-4.0\examples\Width_3. However, when I open
the project Width_3_example.sln by vs2010, there's only one warnning without
any error when I build solution. But when I try to debugging or start
without debugging, error happens:
http://cgal-discuss.949826.n4.nabble.com/file/n4554192/%E6%89%BE%E4%B8%8D%E5%88%B0ALL_BUILD%E2%80%94%E2%80%941.bmp
So, what's the matter?
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/How-to-use-the-examples-of-CGAL-tp4553639p4554192.html
- [cgal-discuss] How to use the examples of CGAL, daisy, 04/13/2012
- <Possible follow-up(s)>
- [cgal-discuss] Re: How to use the examples of CGAL, daisy, 04/13/2012
- Re: [cgal-discuss] Re: How to use the examples of CGAL, Laurent Rineau (GeometryFactory), 04/13/2012
- [cgal-discuss] Re: How to use the examples of CGAL, daisy, 04/14/2012
- Re: [cgal-discuss] Re: How to use the examples of CGAL, Philipp Moeller, 04/14/2012
