cgal-discuss - Re: [cgal-discuss] Bug of funciton 'edge_collapse'?
  • To:
  • Subject: Re: [cgal-discuss] Bug of funciton 'edge_collapse'?
  • Date: Thu, 04 Oct 2012 16:41:44 +0200
Could you please provide a complete example showing the problem?
(by complete I mean a cpp file I can compile and run)
Thanks,
Sebastien.
On 10/04/2012 04:38 PM, tang wrote:
Dear all,
By further test, I found that when set edgelengthmin=1.e-14, no any edge is
removed (the result of this funciton return 0, i.e., r=0). However, the
output file a11.off has 58 triangles which have duplicated vertices (the
coordinates of two vertices are exactly the same).
Could anyone help me to take a look at this problem?
Thanks,
Zhanghong Tang
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Simplify-function-doesn-t-work-tp4655966p4655968.html
