- To:
- Subject: Re: [cgal-discuss] Re: Bug of funciton 'edge_collapse'?
- Date: Fri, 05 Oct 2012 14:53:24 +0200
On 10/05/2012 02:36 PM, tang wrote:
Dear Dr. Loriot,So it should be correct.
Thank you very much for your quick reply. I think I used the same kernel:
typedef CGAL::Exact_predicates_exact_constructions_kernel
Kernel;
typedef Kernel::Point_3
Point_3;
typedef Kernel::Line_3
Line_3;
typedef CGAL::Nef_polyhedron_3<Kernel>
Nef_polyhedron;
typedef GAL::Polyhedron_3<Kernel>
Polyhedron;
Isn't it?
In your pipeline, are you writing file to the disk or are you using the polyhedron in memory?
I think when you write to the disk the polyhedron, you convert it do double.
Sebastien.
Thanks,
Zhanghong Tang
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Simplify-function-doesn-t-work-tp4655966p4655989.html
- Re: [cgal-discuss] Bug of funciton 'edge_collapse'?, (continued)
- Re: [cgal-discuss] Bug of funciton 'edge_collapse'?, Sebastien Loriot (GeometryFactory), 10/04/2012
- [cgal-discuss] Re: Bug of funciton 'edge_collapse'?, tang, 10/04/2012
- Re: [cgal-discuss] Re: Bug of funciton 'edge_collapse'?, Sebastien Loriot (GeometryFactory), 10/04/2012
- [cgal-discuss] Re: Bug of funciton 'edge_collapse'?, tang, 10/05/2012
- Re: [cgal-discuss] Re: Bug of funciton 'edge_collapse'?, Sebastien Loriot (GeometryFactory), 10/05/2012
- Re: [cgal-discuss] Re: Bug of funciton 'edge_collapse'?, Laurent Rineau (CGAL/GeometryFactory), 10/04/2012
