- To:
- Subject: [cgal-discuss] Re: Bug of funciton 'edge_collapse'?
- Date: Thu, 4 Oct 2012 09:39:07 -0700 (PDT)
Dear Dr. Loriot,
Thank you very much for your kindly check and reply. This mode is generated
by boolean operations of polyhedron by CGAL. Is there any problem in CGAL's
boolean operation modules?
On the other hand, could you please give me some hints on how to check and
fix the problem of 'self-intersection' in the model defined by 'Polyhedron'?
Thanks,
Zhanghong Tang
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Simplify-function-doesn-t-work-tp4655966p4655978.html
- [cgal-discuss] Simplify function doesn't work?, tang, 10/04/2012
- [cgal-discuss] Bug of funciton 'edge_collapse'?, tang, 10/04/2012
- Re: [cgal-discuss] Bug of funciton 'edge_collapse'?, Sebastien Loriot (GeometryFactory), 10/04/2012
- [cgal-discuss] Re: Bug of funciton 'edge_collapse'?, tang, 10/04/2012
- Re: [cgal-discuss] Re: Bug of funciton 'edge_collapse'?, Sebastien Loriot (GeometryFactory), 10/04/2012
- [cgal-discuss] Re: Bug of funciton 'edge_collapse'?, tang, 10/05/2012
- Re: [cgal-discuss] Re: Bug of funciton 'edge_collapse'?, Sebastien Loriot (GeometryFactory), 10/05/2012
