cgal-discuss - Re: [cgal-discuss] Re: Bug of funciton 'edge_collapse'?
  • To:
  • Subject: Re: [cgal-discuss] Re: Bug of funciton 'edge_collapse'?
  • Date: Thu, 04 Oct 2012 19:06:38 +0200
On 10/04/2012 06:39 PM, tang wrote:
Dear Dr. Loriot,
Thank you very much for your kindly check and reply. This mode is generated
by boolean operations of polyhedron by CGAL. Is there any problem in CGAL's
boolean operation modules?
I cannot guess what you did to produce your model. If you used nef, it's probably due to the output precision of your model.
On the other hand, could you please give me some hints on how to check and
fix the problem of 'self-intersection' in the model defined by 'Polyhedron'?
you can use the polyhedron demo and the self-intersection plugin to detect them.
Sebastien.
Thanks,
Zhanghong Tang
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Simplify-function-doesn-t-work-tp4655966p4655978.html
