cgal-discuss - Re: [cgal-discuss] Re: Bug of funciton 'edge_collapse'?
  • To:
  • Subject: Re: [cgal-discuss] Re: Bug of funciton 'edge_collapse'?
  • Date: Fri, 05 Oct 2012 14:24:36 +0200
Use the same same Kernel you use in Nef_polyhedron for Polyhedron.
Sebastien.
On 10/05/2012 02:22 PM, tang wrote:
Dear Dr. Loriot,
Thank you very much for you point out the problem. In my code, the included
header files are exactly the same as 'code.cpp' I posted before, could you
please give me some suggestion on how to do to let the boolean operations
use exact number type and then avoid self-intersection?
Thanks,
Zhanghong Tang
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Simplify-function-doesn-t-work-tp4655966p4655987.html
