cgal-discuss - [cgal-discuss] Re: Bug of funciton 'edge_collapse'?
  • To:
  • Subject: [cgal-discuss] Re: Bug of funciton 'edge_collapse'?
  • Date: Thu, 4 Oct 2012 17:07:01 -0700 (PDT)
Dear Dr. Loriot,
Thank you very much for your kindly reply. I will test the self-intersection
plug in and try to know how to let it work on my case.
On the other hand, the real case is that I didn't output the OFF file and
let the function 'SimplifySurfaceMeshCGAL' read OFF file. My work is to
create cylinders and boxs (of cause they are all polyhedrons) and then let
the CGAL to do boolean operations to combine all these objects to the final
one. The funcitons 'SimplifySurfaceMeshCGAL' directly works on the final
polyhedron. My questions are:
1) for the raw OFF file (a1.off) outputted by CGAL, what could lead to
'self-intersection' and duplicated vertices on some triangles?
2) why the function 'SimplifySurfaceMeshCGAL' still can't remove the
duplicated vertices (with edge length < 1.e-14) when the data is directly
from boolean operations result?
Thanks,
Zhanghong Tang
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Simplify-function-doesn-t-work-tp4655966p4655985.html
