- To:
- Subject: [cgal-discuss] Re: Bug of funciton 'edge_collapse'?
- Date: Fri, 5 Oct 2012 05:22:56 -0700 (PDT)
Dear Dr. Loriot,
Thank you very much for you point out the problem. In my code, the included
header files are exactly the same as 'code.cpp' I posted before, could you
please give me some suggestion on how to do to let the boolean operations
use exact number type and then avoid self-intersection?
Thanks,
Zhanghong Tang
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Simplify-function-doesn-t-work-tp4655966p4655987.html
- [cgal-discuss] Simplify function doesn't work?, tang, 10/04/2012
- [cgal-discuss] Bug of funciton 'edge_collapse'?, tang, 10/04/2012
- Re: [cgal-discuss] Bug of funciton 'edge_collapse'?, Sebastien Loriot (GeometryFactory), 10/04/2012
- [cgal-discuss] Re: Bug of funciton 'edge_collapse'?, tang, 10/04/2012
- Re: [cgal-discuss] Re: Bug of funciton 'edge_collapse'?, Sebastien Loriot (GeometryFactory), 10/04/2012
- [cgal-discuss] Re: Bug of funciton 'edge_collapse'?, tang, 10/05/2012
- Re: [cgal-discuss] Re: Bug of funciton 'edge_collapse'?, Sebastien Loriot (GeometryFactory), 10/05/2012
- Re: [cgal-discuss] Re: Bug of funciton 'edge_collapse'?, Laurent Rineau (CGAL/GeometryFactory), 10/04/2012
