- To:
- Subject: [cgal-discuss] Re: failing to compile simple code under VS2010
- Date: Fri, 9 Nov 2012 00:30:31 -0800 (PST)
I havent forget, but it returned some errors.
here's the attempt of release mode:
------ Build started: Project: ZERO_CHECK, Configuration: Release Win32
Build started 11/9/2012 10:27:46 AM.
InitializeBuildStatus:
Creating "Win32\Release\ZERO_CHECK\ZERO_CHECK.unsuccessfulbuild" because
"AlwaysCreate" was specified.
FinalizeBuildStatus:
Deleting file "Win32\Release\ZERO_CHECK\ZERO_CHECK.unsuccessfulbuild".
Touching "Win32\Release\ZERO_CHECK\ZERO_CHECK.lastbuildstate".
Build succeeded.
Time Elapsed 00:00:00.42
------ Build started: Project: CGAL, Configuration: Release Win32 ------
Touching "CGAL.dir\Release\CGAL.unsuccessfulbuild".
CustomBuild:
All outputs are up-to-date.
ClCompile:
ResourceCompile:
LINK : fatal error LNK1104: cannot open file
'boost_thread-vc100-mt-1_47.lib'
Build FAILED.
Time Elapsed 00:00:00.87
------ Build started: Project: CGAL_Core, Configuration: Release Win32
Build started 11/9/2012 10:27:48 AM.
Touching "CGAL_Core.dir\Release\CGAL_Core.unsuccessfulbuild".
CustomBuild:
ClCompile:
ResourceCompile:
LINK : fatal error LNK1104: cannot open file 'CGAL-vc100-mt-4.1.lib'
Build FAILED.
Time Elapsed 00:00:00.21
------ Build started: Project: CGAL_ImageIO, Configuration: Release Win32
Touching "CGAL_ImageIO.dir\Release\CGAL_ImageIO.unsuccessfulbuild".
CustomBuild:
ClCompile:
all_files.cpp
c:\program files (x86)\gnuwin32\include\zconf.h(289): fatal error C1083:
Cannot open include file: 'unistd.h': No such file or directory
Build FAILED.
Time Elapsed 00:00:00.45
------ Build started: Project: CGAL_Qt4, Configuration: Release Win32 ------
Build started 11/9/2012 10:27:49 AM.
Touching "CGAL_Qt4.dir\Release\CGAL_Qt4.unsuccessfulbuild".
CustomBuild:
ClCompile:
ResourceCompile:
Build FAILED.
Time Elapsed 00:00:00.39
------ Build started: Project: ALL_BUILD, Configuration: Release Win32
Creating "Win32\Release\ALL_BUILD\ALL_BUILD.unsuccessfulbuild" because
CustomBuild:
Build all projects
Deleting file "Win32\Release\ALL_BUILD\ALL_BUILD.unsuccessfulbuild".
Touching "Win32\Release\ALL_BUILD\ALL_BUILD.lastbuildstate".
Build succeeded.
Time Elapsed 00:00:00.12
========== Build: 2 succeeded, 4 failed, 0 up-to-date, 0 skipped ==========
but im not really sure what to do with it.
Im new with VS (i usually work on linux)
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/failing-to-compile-simple-code-under-VS2010-tp4656187p4656189.html
- [cgal-discuss] failing to compile simple code under VS2010, Eran Yanay, 11/08/2012
- Re: [cgal-discuss] failing to compile simple code under VS2010, Laurent Rineau (CGAL/GeometryFactory), 11/09/2012
- [cgal-discuss] Re: failing to compile simple code under VS2010, Eran Yanay, 11/09/2012
- Re: [cgal-discuss] Re: failing to compile simple code under VS2010, Laurent Rineau (CGAL/GeometryFactory), 11/09/2012
