- To:
- Subject: [cgal-discuss] Re: failing to compile simple code under VS2010
- Date: Fri, 9 Nov 2012 03:06:19 -0800 (PST)
the boolean you suggested did help, that line has disappeared from the new
log,
however, the same issue remains
the updated log is here:
http://pastebin.com/aDUkcCAU
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/failing-to-compile-simple-code-under-VS2010-tp4656187p4656199.html
- [cgal-discuss] failing to compile simple code under VS2010, Eran Yanay, 11/08/2012
- Re: [cgal-discuss] failing to compile simple code under VS2010, Laurent Rineau (CGAL/GeometryFactory), 11/09/2012
- [cgal-discuss] Re: failing to compile simple code under VS2010, Eran Yanay, 11/09/2012
- Re: [cgal-discuss] Re: failing to compile simple code under VS2010, Laurent Rineau (CGAL/GeometryFactory), 11/09/2012
- [cgal-discuss] Re: failing to compile simple code under VS2010, Daniel S., 11/09/2012
