- To:
- Subject: Re: [cgal-discuss] Re: failing to compile simple code under VS2010
- Date: Fri, 09 Nov 2012 11:37:52 +0100
Le vendredi 09 novembre 2012 02:01:36 Eran Yanay a écrit :
> actually i have checked and my boost library contains alot of libraries.
> even the boost_thread and others which is written.
> however, they all begin with "lib" prefix, like "libboost.....lib" and i
> think thats the issue.
> is it safe to rename it and press the configure button again?
> or does it have some dependencies i need to take into account?
The Boost libraries starting with libboost* are static libraries. Those
starting with boost* are shared libraries.
In CMake, you can toggle the boolean variable CGAL_Boost_USE_STATIC_LIBS so
that the CGAL CMake scripts set variables so that FindBoost.cmake searchs for
static Boost libraries.
Laurent Rineau, PhD
- [cgal-discuss] failing to compile simple code under VS2010, Eran Yanay, 11/08/2012
- Re: [cgal-discuss] failing to compile simple code under VS2010, Laurent Rineau (CGAL/GeometryFactory), 11/09/2012
- [cgal-discuss] Re: failing to compile simple code under VS2010, Eran Yanay, 11/09/2012
- Re: [cgal-discuss] Re: failing to compile simple code under VS2010, Laurent Rineau (CGAL/GeometryFactory), 11/09/2012
- [cgal-discuss] Re: failing to compile simple code under VS2010, Daniel S., 11/09/2012
