- To:
- Subject: [cgal-discuss] Re: failing to compile simple code under VS2010
- Date: Fri, 9 Nov 2012 00:47:53 -0800 (PST)
im having some hard time with cmake-gui
i have this message:
CMake Error at C:/Program Files (x86)/CMake
2.8/share/cmake-2.8/Modules/FindBoost.cmake:1200 (message):
Unable to find the requested Boost libraries.
Boost version: 1.47.0
Boost include path: C:/Program Files (x86)/boost/boost_1_47
The following Boost libraries could not be found:
boost_thread
boost_system
No Boost libraries were found. You may need to set BOOST_LIBRARYDIR to
the
directory containing Boost libraries or BOOST_ROOT to the location of
Boost.
Call Stack (most recent call first):
cmake/modules/CGAL_SetupBoost.cmake:6 (find_package)
cmake/modules/CGAL_SetupDependencies.cmake:85 (include)
CMakeLists.txt:590 (include)
which because of it, it says it may be invalid.
of course, i have defined the librarydir path as the error says and it
points to c:/.../boost/boost_1_47/lib
and boost root dir to C:/.../boost/boost_1_47/
but pressing configuration again leads to the same error
what am i missing?
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/failing-to-compile-simple-code-under-VS2010-tp4656187p4656191.html
- [cgal-discuss] failing to compile simple code under VS2010, Eran Yanay, 11/08/2012
- Re: [cgal-discuss] failing to compile simple code under VS2010, Laurent Rineau (CGAL/GeometryFactory), 11/09/2012
- [cgal-discuss] Re: failing to compile simple code under VS2010, Eran Yanay, 11/09/2012
- Re: [cgal-discuss] Re: failing to compile simple code under VS2010, Laurent Rineau (CGAL/GeometryFactory), 11/09/2012
- [cgal-discuss] Re: failing to compile simple code under VS2010, Daniel S., 11/09/2012
