cgal-discuss - Re: [cgal-discuss] Re: failing to compile simple code under VS2010
  • To:
  • Subject: Re: [cgal-discuss] Re: failing to compile simple code under VS2010
  • Date: Fri, 09 Nov 2012 13:29:40 +0100
Le vendredi 09 novembre 2012 03:55:23 Eran Yanay a écrit :
> some progress, at last
> i cleared cache, added the booleans & paths of boost
> and it compiled ok, finished with no errors with the following log:
> http://pastebin.com/6njpqiHG
> then i pressed generate, and opened the CGAL file from CGAL-4.1/ and then i
> pressed build for release mode.
> previously i had 2 success and 4 fails, now its the opposite.
> thats the log from VS2010:
> http://pastebin.com/FApQ8AEk
For some reason, that the log does not explain, GMP is not linked with
CGAL_Core. You can ignore failures of CGAL_ImageIO with ZLIB (you can compile
CGAL with WITH_CGAL_ImageIO=OFF if you do not want to see the error).
For GMP not used during the link of CGAL_COre, I do not understand what
happened. Try to find out in the CGAL_Core.vcproj which linking flags are
used.
Laurent Rineau, PhD
