cgal-discuss - Re: [cgal-discuss] Re: failing to compile simple code under VS2010
  • To:
  • Subject: Re: [cgal-discuss] Re: failing to compile simple code under VS2010
  • Date: Fri, 09 Nov 2012 09:55:12 +0100
Le vendredi 09 novembre 2012 00:47:53 Eran Yanay a écrit :
> im having some hard time with cmake-gui
> i have this message:
> CMake Error at C:/Program Files (x86)/CMake
> 2.8/share/cmake-2.8/Modules/FindBoost.cmake:1200 (message):
> Unable to find the requested Boost libraries.
> Boost version: 1.47.0
> Boost include path: C:/Program Files (x86)/boost/boost_1_47
> The following Boost libraries could not be found:
> boost_thread
> boost_system
> No Boost libraries were found. You may need to set BOOST_LIBRARYDIR to
> the
> directory containing Boost libraries or BOOST_ROOT to the location of
> Boost.
> Call Stack (most recent call first):
> cmake/modules/CGAL_SetupBoost.cmake:6 (find_package)
> cmake/modules/CGAL_SetupDependencies.cmake:85 (include)
> CMakeLists.txt:590 (include)
> which because of it, it says it may be invalid.
> of course, i have defined the librarydir path as the error says and it
> points to c:/.../boost/boost_1_47/lib
> and boost root dir to C:/.../boost/boost_1_47/
> but pressing configuration again leads to the same error
> what am i missing?
You can create a new BOOL cmake variable Boost_DEBUG, and turn it ON. That
gives more verbose messages.
Probably your directory c:/.../boost/boost_1_47/lib does not contain the
needed libraries. Have you installed precompiled Boost libraries, using the
installer provided by the BoostPro company? If not, you should compile the
Boost libraries.
Have a look at the following page:
http://www.cgal.org/windows_installation.html
It was written, cross-checked, and approved by several CGAL developers.
Laurent Rineau, PhD
