cgal-discuss - [cgal-discuss] Re: failing to compile simple code under VS2010
  • To:
  • Subject: [cgal-discuss] Re: failing to compile simple code under VS2010
  • Date: Fri, 9 Nov 2012 03:55:23 -0800 (PST)
some progress, at last
i cleared cache, added the booleans & paths of boost
and it compiled ok, finished with no errors with the following log:
http://pastebin.com/6njpqiHG
then i pressed generate, and opened the CGAL file from CGAL-4.1/ and then i
pressed build for release mode.
previously i had 2 success and 4 fails, now its the opposite.
thats the log from VS2010:
http://pastebin.com/FApQ8AEk
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/failing-to-compile-simple-code-under-VS2010-tp4656187p4656200.html
