- To:
- Subject: Re: [cgal-discuss] Re: failing to compile simple code under VS2010
- Date: Fri, 09 Nov 2012 09:35:01 +0100
Le vendredi 09 novembre 2012 00:30:31 Eran Yanay a écrit :
> ------ Build started: Project: CGAL, Configuration: Release Win32 ------
> Build started 11/9/2012 10:27:46 AM.
> InitializeBuildStatus:
> Touching "CGAL.dir\Release\CGAL.unsuccessfulbuild".
> CustomBuild:
> All outputs are up-to-date.
> ClCompile:
> ResourceCompile:
> LINK : fatal error LNK1104: cannot open file
> 'boost_thread-vc100-mt-1_47.lib'
> Build FAILED.
What I have cited above is the summary of your problem: the CGAL.lib target
cannot be created, because of a configuration issue of Boost. Verify your
CMake configuration.
Laurent Rineau, PhD
- [cgal-discuss] failing to compile simple code under VS2010, Eran Yanay, 11/08/2012
- Re: [cgal-discuss] failing to compile simple code under VS2010, Laurent Rineau (CGAL/GeometryFactory), 11/09/2012
- [cgal-discuss] Re: failing to compile simple code under VS2010, Eran Yanay, 11/09/2012
- Re: [cgal-discuss] Re: failing to compile simple code under VS2010, Laurent Rineau (CGAL/GeometryFactory), 11/09/2012
- [cgal-discuss] Re: failing to compile simple code under VS2010, Daniel S., 11/09/2012
