coq-club - Re: [Coq-Club] local definition in proof mode
chronological Thread
  • From: St�phane Lescuyer <stephane.lescuyer AT inria.fr>
  • To: andr� hirschowitz <ah AT unice.fr>
  • Cc: Martijn Vermaat <martijn AT vermaat.name>, coq-club AT inria.fr
  • Subject: Re: [Coq-Club] local definition in proof mode
  • Date: Tue, 6 Apr 2010 13:32:57 +0200
I don't see what is the problem with assert, "assert (H : P)" is
basically "cut P" with the goals generated the other way, so it is
exactly what you asked for in your first message ; in particular, it
does add an hypothesis named H of type P in the second goal.
Note that assert can be used as pose as well : "assert (H := t)" will
act as "pose (H := t); clearbody H".
HTH,
Stéphane
On Tue, Apr 6, 2010 at 1:22 PM, andré hirschowitz
<ah AT unice.fr>
 wrote:
> no, if I experiment correctly.
> assert generates two goals and does not forward to the second one the
> formula produced for the first one.
> Thanks for your answer.
> ah
>> I think you are looking for the following?
>>  assert (myname : mytype).
I'm the kind of guy that until it happens, I won't worry about it. -
R.H. RoY05, MVP06
