- From: Jean-Francois Monin <jean-francois.monin AT imag.fr>
- To: St�phane Lescuyer <stephane.lescuyer AT inria.fr>
- Cc: andr� hirschowitz <ah AT unice.fr>, Martijn Vermaat <martijn AT vermaat.name>, coq-club AT inria.fr
- Subject: Re: [Coq-Club] local definition in proof mode
- Date: Tue, 6 Apr 2010 20:07:45 +0800
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=sender:date:from:to:cc:subject:message-id:references:mime-version :content-type:content-disposition:content-transfer-encoding :in-reply-to:user-agent; b=E8Pas5iXYqiQ9LKprgJZuBckwj1lh6cg4BbImVa/cIo7vBVsHfscUcY4CUkha0//3A ziznRDirsHpoVR1BAMHHllb121hj/zKK+XUTGBzVn/C0Ilgt1WXdpwA8KaPTzHj8jlse KNZySWYsCzLYfvwV4fFVoL4++Mu/5RSYr3Bx4=
As far as i understand, the very value of H may be useful
and defining it in one step may be hard.
Example:
Goal forall x : X, exists y: Y, complicated_property x y.
intros x. pose (y: Y).
apply many_functions_in_order_to_build_y_from_x.
exists y. apply many_lemmas_for_proving_complicated_property_x_y.
Qed.
Here neither cut nor assert is the answer.
JF
On Tue, Apr 06, 2010 at 01:32:57PM +0200, Stéphane Lescuyer wrote:
> I don't see what is the problem with assert, "assert (H : P)" is
> basically "cut P" with the goals generated the other way, so it is
> exactly what you asked for in your first message ; in particular, it
> does add an hypothesis named H of type P in the second goal.
> Note that assert can be used as pose as well : "assert (H := t)" will
> act as "pose (H := t); clearbody H".
> HTH,
> Stéphane
> On Tue, Apr 6, 2010 at 1:22 PM, andré hirschowitz
>Â <ah AT unice.fr>
> wrote:
> > no, if I experiment correctly.
> > assert generates two goals and does not forward to the second one the
> > formula produced for the first one.
> > Thanks for your answer.
> > ah
> >> I think you are looking for the following?
> >> assert (myname : mytype).
Jean-Francois Monin
CNRS-LIAMA, Project FORMES & Universite de Grenoble 1
Office 3-605, FIT, Tsinghua University
Haidian District, Beijing 100084, CHINA
Tel: +86 10 62 79 69 79 ext 605
Fax@LIAMA:
+86 10 6264 7458
- [Coq-Club] local definition in proof mode, andré hirschowitz
- Re: [Coq-Club] local definition in proof mode,
Martijn Vermaat
andré hirschowitz
Stéphane Lescuyer
Guillaume Allais
- Re: [Coq-Club] local definition in proof mode, Pierre-Marie Pédrot
- Re: [Coq-Club] local definition in proof mode, Jean-Francois Monin
AUGER
andré hirschowitz
AUGER
- Re: [Coq-Club] local definition in proof mode, AUGER
- Re: [Coq-Club] local definition in proof mode, Pierre Courtieu
andré hirschowitz
Guillaume Allais
Stéphane Lescuyer
andré hirschowitz
Martijn Vermaat
