coq-club - Re: [Coq-Club] [Agda] Re: [HoTT] newbie questions about homotopy theory & advantage of UF/Coq
  • To: Abhishek Anand <abhishek.anand.iitg AT gmail.com>
  • Cc: "agda AT lists.chalmers.se" <agda AT lists.chalmers.se>, coq-club Club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] [Agda] Re: [HoTT] newbie questions about homotopy theory & advantage of UF/Coq
  • Date: Mon, 06 Jan 2014 19:50:50 -0500
Well, my example does not typecheck with the --without-K flag.
However, the same thing can be proven in Coq without K, so I am not sure if it is because the flag is too restrictive or because Agda's pattern matching is different.
I am also not sure how specific the problem is to univalence. As Cody said, I would expect to find some set-theoretical models where the equality holds. So being able to prove the negation is disturbing.
Maxime.
On 01/06/2014 07:23 PM, Abhishek Anand wrote:
It is known that UIP is inconsistent with univalence.
Does this typecheck even after disabling UIP(==K axiom?) ?
I might be wrong, but I think that UIP is baked into the typechecker of Agda.
But, UIP can be disabled somehow?
-- Abhishek
http://www.cs.cornell.edu/~aa755/ <http://www.cs.cornell.edu/%7Eaa755/>
On Mon, Jan 6, 2014 at 3:42 PM, Maxime Dénès <mail AT maximedenes.fr <mailto:mail AT maximedenes.fr>> wrote:
Bingo, Agda seems to have the same problem:
module Termination where
open import Relation.Binary.Core
data Empty : Set where
data Box : Set where
wrap : (Empty → Box) → Box
postulate
iso : (Empty → Box) ≡ Box
loop : Box -> Empty
loop (wrap x) rewrite iso = loop x
gift : Empty → Box
gift ()
bug : Empty
bug = loop (wrap gift)
However, I may be missing something due to my ignorance of Agda.
It may be well known that the axiom I introduced is inconsistent.
Forgive me if it is the case.
Maxime.
On 01/06/2014 01:15 PM, Maxime Dénès wrote:
The anti-extensionality bug is indeed related to termination.
More precisely, it is the subterm relation used by the guard
checker which is not defined quite the right way on dependent
pattern matching.
It is not too hard to fix (we have a patch), but doing so
without ruling out any interesting legitimate example (dealing
with recursion on dependently typed data structures) is more
challenging.
I am also curious as to whether Agda is impacted. Let's try it :)
Maxime.
On 01/06/2014 12:59 PM, Altenkirch Thorsten wrote:
Which bug was this?
I only saw the one which allowed you to prove
anti-extensionality? But
this wasn't related to termination, or?
Thorsten
On 06/01/2014 16:54, "Cody Roux"
<cody.roux AT andrew.cmu.edu
<mailto:cody.roux AT andrew.cmu.edu>>
wrote:
Nice summary!
On 01/06/2014 08:49 AM, Altenkirch Thorsten wrote:
Agda enforces termination via a termination
checker which is more
flexible but I think less principled than Coq's
approach.
That's a bit scary given that there was an
inconsistency found in
the Coq termination checker just a couple of weeks ago :)
BTW, has anyone tried reproducing the bug in Agda?
Cody
This message and any attachment are intended solely for
the addressee and may contain confidential information. If
you have received this message in error, please send it
back to me, and immediately delete it. Please do not use,
copy or disclose the information contained in this message
or in any attachment. Any views or opinions expressed by
the author of this email do not necessarily reflect the
views of the University of Nottingham.
This message has been checked for viruses but the contents
of an attachment
may still contain software viruses which could damage your
computer system, you are advised to perform your own
checks. Email communications with the University of
Nottingham may be monitored as permitted by UK legislation.
_______________________________________________
Agda mailing list
Agda AT lists.chalmers.se
<mailto:Agda AT lists.chalmers.se>
https://lists.chalmers.se/mailman/listinfo/agda
Agda mailing list
