Re: [Coq-Club] [Agda] Re: [HoTT] newbie questions about homotopy theory & advantage of UF/Coq
- From: Conor McBride <conor AT strictlypositive.org>
- To: Altenkirch Thorsten <psztxa AT exmail.nottingham.ac.uk>
- Cc: Maxime Dénès <mail AT maximedenes.fr>, Abhishek Anand <abhishek.anand.iitg AT gmail.com>, coq-club Club <coq-club AT inria.fr>, "agda AT lists.chalmers.se" <agda AT lists.chalmers.se>
- Subject: Re: [Coq-Club] [Agda] Re: [HoTT] newbie questions about homotopy theory & advantage of UF/Coq
- Date: Tue, 7 Jan 2014 16:42:37 +0000
On 7 Jan 2014, at 09:28, Altenkirch Thorsten
wrote:
> On 07/01/2014 00:50, "Maxime Dénès"
> wrote:
>> Well, my example does not typecheck with the --without-K flag.
>> However, the same thing can be proven in Coq without K, so I am not sure
>> if it is because the flag is too restrictive or because Agda's pattern
>> matching is different.
> Very good. Agda is right and Coq got it wrong. As I said previosuly the
> definition of loop implicitely uses K.
Not so fast! The code below is accepted using the --without-K flag, and
the elimination that noo does is a based path induction, IIUC.
Conor
{-# OPTIONS --without-K #-}
module BadWithoutK where
data Zero : Set where
data WOne : Set where
wrap : (Zero -> WOne) -> WOne
data _<->_ (X : Set) : Set -> Set where
Refl : X <-> X
postulate
myIso : WOne <-> (Zero -> WOne)
moo : WOne -> Zero
noo : (X : Set) -> (WOne <-> X) -> X -> Zero
moo (wrap f) = noo (Zero -> WOne) myIso f
noo .WOne Refl x = moo x
bad : Zero
bad = moo (wrap \ ())
> T.
>> I am also not sure how specific the problem is to univalence. As Cody
>> said, I would expect to find some set-theoretical models where the
>> equality holds. So being able to prove the negation is disturbing.
>> Maxime.
>> On 01/06/2014 07:23 PM, Abhishek Anand wrote:
>>> It is known that UIP is inconsistent with univalence.
>>> Does this typecheck even after disabling UIP(==K axiom?) ?
>>> I might be wrong, but I think that UIP is baked into the typechecker
>>> of Agda.
>>> But, UIP can be disabled somehow?
>>> -- Abhishek
>>> http://www.cs.cornell.edu/~aa755/ <http://www.cs.cornell.edu/%7Eaa755/>
>>> On Mon, Jan 6, 2014 at 3:42 PM, Maxime Dénès
>>> <mailto:mail AT maximedenes.fr>>
>>> wrote:
>>> Bingo, Agda seems to have the same problem:
>>> module Termination where
>>> open import Relation.Binary.Core
>>> data Empty : Set where
>>> data Box : Set where
>>> wrap : (Empty → Box) → Box
>>> postulate
>>> iso : (Empty → Box) ≡ Box
>>> loop : Box -> Empty
>>> loop (wrap x) rewrite iso = loop x
>>> gift : Empty → Box
>>> gift ()
>>> bug : Empty
>>> bug = loop (wrap gift)
>>> However, I may be missing something due to my ignorance of Agda.
>>> It may be well known that the axiom I introduced is inconsistent.
>>> Forgive me if it is the case.
>>> Maxime.
>>> On 01/06/2014 01:15 PM, Maxime Dénès wrote:
>>> The anti-extensionality bug is indeed related to termination.
>>> More precisely, it is the subterm relation used by the guard
>>> checker which is not defined quite the right way on dependent
>>> pattern matching.
>>> It is not too hard to fix (we have a patch), but doing so
>>> without ruling out any interesting legitimate example (dealing
>>> with recursion on dependently typed data structures) is more
>>> challenging.
>>> I am also curious as to whether Agda is impacted. Let's try it
>>> Maxime.
>>> On 01/06/2014 12:59 PM, Altenkirch Thorsten wrote:
>>> Which bug was this?
>>> I only saw the one which allowed you to prove
>>> anti-extensionality? But
>>> this wasn't related to termination, or?
>>> Thorsten
>>> On 06/01/2014 16:54, "Cody Roux"
>>> <cody.roux AT andrew.cmu.edu
>>> <mailto:cody.roux AT andrew.cmu.edu>>
>>> wrote:
>>> Nice summary!
>>> On 01/06/2014 08:49 AM, Altenkirch Thorsten wrote:
>>> Agda enforces termination via a termination
>>> checker which is more
>>> flexible but I think less principled than Coq's
>>> approach.
>>> That's a bit scary given that there was an
>>> inconsistency found in
>>> the Coq termination checker just a couple of weeks ago
>>> BTW, has anyone tried reproducing the bug in Agda?
>>> Cody
>>> This message and any attachment are intended solely for
>>> the addressee and may contain confidential information. If
>>> you have received this message in error, please send it
>>> back to me, and immediately delete it. Please do not use,
>>> copy or disclose the information contained in this message
>>> or in any attachment. Any views or opinions expressed by
>>> the author of this email do not necessarily reflect the
>>> views of the University of Nottingham.
>>> This message has been checked for viruses but the contents
>>> of an attachment
>>> may still contain software viruses which could damage your
>>> computer system, you are advised to perform your own
>>> checks. Email communications with the University of
>>> Nottingham may be monitored as permitted by UK legislation.
>>> _______________________________________________
>>> Agda mailing list
>>> Agda AT lists.chalmers.se
>>> <mailto:Agda AT lists.chalmers.se>
>>> https://lists.chalmers.se/mailman/listinfo/agda
>>> Agda mailing list
>> Agda mailing list
> Agda mailing list
- Re: [Coq-Club] [Agda] Re: [HoTT] newbie questions about homotopy theory & advantage of UF/Coq, (continued)
- Re: [Coq-Club] [Agda] Re: [HoTT] newbie questions about homotopy theory & advantage of UF/Coq, Vladimir Voevodsky, 01/09/2014
- Re: [Coq-Club] [Agda] Re: [HoTT] newbie questions about homotopy theory & advantage of UF/Coq, Matthieu Sozeau, 01/09/2014
- Re: [Coq-Club] [Agda] Re: [HoTT] newbie questions about homotopy theory & advantage of UF/Coq, Frédéric Blanqui, 01/09/2014
- Re: [Coq-Club] [Agda] Re: [HoTT] newbie questions about homotopy theory & advantage of UF/Coq, Andreas Abel, 01/09/2014
- Re: [Coq-Club] [Agda] Re: [HoTT] newbie questions about homotopy theory & advantage of UF/Coq, Altenkirch Thorsten, 01/09/2014
- Re: [Coq-Club] [Agda] Re: [HoTT] newbie questions about homotopy theory & advantage of UF/Coq, Maxime Dénès, 01/07/2014
- Re: [Coq-Club] [Agda] Re: [HoTT] newbie questions about homotopy theory & advantage of UF/Coq, Altenkirch Thorsten, 01/07/2014
- Re: [Coq-Club] [Agda] Re: [HoTT] newbie questions about homotopy theory & advantage of UF/Coq, Conor McBride, 01/07/2014
- Re: [Coq-Club] [Agda] Re: [HoTT] newbie questions about homotopy theory & advantage of UF/Coq, Dan Doel, 01/08/2014
- Re: [Coq-Club] [Agda] Re: [HoTT] newbie questions about homotopy theory & advantage of UF/Coq, Frédéric Blanqui, 01/08/2014
