Re: [Coq-Club] [Agda] Re: [HoTT] newbie questions about homotopy theory & advantage of UF/Coq
- From: Altenkirch Thorsten <psztxa AT exmail.nottingham.ac.uk>
- To: Maxime Dénès <mail AT maximedenes.fr>, Abhishek Anand <abhishek.anand.iitg AT gmail.com>
- Cc: coq-club Club <coq-club AT inria.fr>, "agda AT lists.chalmers.se" <agda AT lists.chalmers.se>
- Subject: Re: [Coq-Club] [Agda] Re: [HoTT] newbie questions about homotopy theory & advantage of UF/Coq
- Date: Tue, 7 Jan 2014 09:28:55 +0000
- Accept-language: en-US, en-GB
- Acceptlanguage: en-US, en-GB
On 07/01/2014 00:50, "Maxime Dénès"
wrote:
>Well, my example does not typecheck with the --without-K flag.
>However, the same thing can be proven in Coq without K, so I am not sure
>if it is because the flag is too restrictive or because Agda's pattern
>matching is different.
Very good. Agda is right and Coq got it wrong. As I said previosuly the
definition of loop implicitely uses K.
T.
>I am also not sure how specific the problem is to univalence. As Cody
>said, I would expect to find some set-theoretical models where the
>equality holds. So being able to prove the negation is disturbing.
>Maxime.
>On 01/06/2014 07:23 PM, Abhishek Anand wrote:
>> It is known that UIP is inconsistent with univalence.
>> Does this typecheck even after disabling UIP(==K axiom?) ?
>> I might be wrong, but I think that UIP is baked into the typechecker
>> of Agda.
>> But, UIP can be disabled somehow?
>> -- Abhishek
>> http://www.cs.cornell.edu/~aa755/ <http://www.cs.cornell.edu/%7Eaa755/>
>> On Mon, Jan 6, 2014 at 3:42 PM, Maxime Dénès
>> <mailto:mail AT maximedenes.fr>>
>> wrote:
>> Bingo, Agda seems to have the same problem:
>> module Termination where
>> open import Relation.Binary.Core
>> data Empty : Set where
>> data Box : Set where
>> wrap : (Empty → Box) → Box
>> postulate
>> iso : (Empty → Box) ≡ Box
>> loop : Box -> Empty
>> loop (wrap x) rewrite iso = loop x
>> gift : Empty → Box
>> gift ()
>> bug : Empty
>> bug = loop (wrap gift)
>> However, I may be missing something due to my ignorance of Agda.
>> It may be well known that the axiom I introduced is inconsistent.
>> Forgive me if it is the case.
>> Maxime.
>> On 01/06/2014 01:15 PM, Maxime Dénès wrote:
>> The anti-extensionality bug is indeed related to termination.
>> More precisely, it is the subterm relation used by the guard
>> checker which is not defined quite the right way on dependent
>> pattern matching.
>> It is not too hard to fix (we have a patch), but doing so
>> without ruling out any interesting legitimate example (dealing
>> with recursion on dependently typed data structures) is more
>> challenging.
>> I am also curious as to whether Agda is impacted. Let's try it
>> Maxime.
>> On 01/06/2014 12:59 PM, Altenkirch Thorsten wrote:
>> Which bug was this?
>> I only saw the one which allowed you to prove
>> anti-extensionality? But
>> this wasn't related to termination, or?
>> Thorsten
>> On 06/01/2014 16:54, "Cody Roux"
>> <cody.roux AT andrew.cmu.edu
>> <mailto:cody.roux AT andrew.cmu.edu>>
>> wrote:
>> Nice summary!
>> On 01/06/2014 08:49 AM, Altenkirch Thorsten wrote:
>> Agda enforces termination via a termination
>> checker which is more
>> flexible but I think less principled than Coq's
>> approach.
>> That's a bit scary given that there was an
>> inconsistency found in
>> the Coq termination checker just a couple of weeks ago
>> BTW, has anyone tried reproducing the bug in Agda?
>> Cody
>> This message and any attachment are intended solely for
>> the addressee and may contain confidential information. If
>> you have received this message in error, please send it
>> back to me, and immediately delete it. Please do not use,
>> copy or disclose the information contained in this message
>> or in any attachment. Any views or opinions expressed by
>> the author of this email do not necessarily reflect the
>> views of the University of Nottingham.
>> This message has been checked for viruses but the contents
>> of an attachment
>> may still contain software viruses which could damage your
>> computer system, you are advised to perform your own
>> checks. Email communications with the University of
>> Nottingham may be monitored as permitted by UK legislation.
>> _______________________________________________
>> Agda mailing list
>> Agda AT lists.chalmers.se
>> <mailto:Agda AT lists.chalmers.se>
>> https://lists.chalmers.se/mailman/listinfo/agda
>> Agda mailing list
>Agda mailing list
- Re: [Coq-Club] [HoTT] newbie questions about homotopy theory & advantage of UF/Coq, (continued)
- Re: [Coq-Club] [HoTT] newbie questions about homotopy theory & advantage of UF/Coq, Matthieu Sozeau, 01/08/2014
- Re: [Coq-Club] [Agda] Re: [HoTT] newbie questions about homotopy theory & advantage of UF/Coq, Vladimir Voevodsky, 01/08/2014
- Re: [Coq-Club] [Agda] Re: [HoTT] newbie questions about homotopy theory & advantage of UF/Coq, Bruno Barras, 01/08/2014
- Re: [Coq-Club] [Agda] Re: [HoTT] newbie questions about homotopy theory & advantage of UF/Coq, Andrej Bauer, 01/08/2014
- Re: [Coq-Club] [Agda] Re: [HoTT] newbie questions about homotopy theory & advantage of UF/Coq, Matthieu Sozeau, 01/09/2014
- Re: [Coq-Club] [Agda] Re: [HoTT] newbie questions about homotopy theory & advantage of UF/Coq, Vladimir Voevodsky, 01/09/2014
- Re: [Coq-Club] [Agda] Re: [HoTT] newbie questions about homotopy theory & advantage of UF/Coq, Maxime Dénès, 01/07/2014
- Re: [Coq-Club] [Agda] Re: [HoTT] newbie questions about homotopy theory & advantage of UF/Coq, Altenkirch Thorsten, 01/07/2014
- Re: [Coq-Club] [Agda] Re: [HoTT] newbie questions about homotopy theory & advantage of UF/Coq, Conor McBride, 01/07/2014
- Re: [Coq-Club] [Agda] Re: [HoTT] newbie questions about homotopy theory & advantage of UF/Coq, Dan Doel, 01/08/2014
- Re: [Coq-Club] [Agda] Re: [HoTT] newbie questions about homotopy theory & advantage of UF/Coq, Frédéric Blanqui, 01/08/2014
