coq-club - Re: [Coq-Club] [Agda] Re: [HoTT] newbie questions about homotopy theory & advantage of UF/Coq
  • From: Frédéric Blanqui <frederic.blanqui AT inria.fr>
  • To: Altenkirch Thorsten <psztxa AT exmail.nottingham.ac.uk>, "cody.roux AT andrew.cmu.edu" <cody.roux AT andrew.cmu.edu>, Vladimir Voevodsky <vladimir AT ias.edu>
  • Cc: Maxime Dénès <mail AT maximedenes.fr>, "homotopytypetheory AT googlegroups.com" <homotopytypetheory AT googlegroups.com>, coq-club Club <coq-club AT inria.fr>, "agda AT lists.chalmers.se" <agda AT lists.chalmers.se>
  • Subject: Re: [Coq-Club] [Agda] Re: [HoTT] newbie questions about homotopy theory & advantage of UF/Coq
  • Date: Thu, 09 Jan 2014 12:06:59 +0100
Le 09/01/2014 11:18, Altenkirch Thorsten a écrit :
Higher-order datatypes are a bit more difficult, and I admit I never
worked it out. I believe it's possible though.
The fact that the implementation is behind the theoretical capabilities
is just that, an implementation problem.
The eliminators are like axioms in set theory and it is worthwhile to
translate any extension by reducing them to the axiom instead of adding
new ones even though they may be semantically justified.
That's fair, but I don't see why eliminators have a more powerful
ontological status than sized-types.
It is maybe not the ontological status but they are a hell easier to write
down!
Do I believe in a foundational system which consists of pages with rules
full of greek (and other alphabets) and super sub and whatever scripts?
Actually I also don't like the schemes for datatypes either, hence I would
like to reduce everything to fixed collection of type formers (we have
done a fair bit of this using containers).
So my target type theory is 0,1,2,Pi,Sigma,Id,U_n with eliminators. Ok we
will need to consider extensions for induction recursion and HITs but they
should also presented by a finite collection of constants with eliminators.
I know there are some gaps in between what we like to do and what we know
it is safe to do but I think we should be able to narrow this gap.
Thorsten
So we have the same goal but not the same answer. ;-) Matter of taste. Because, for me, having just function symbols and rewrite rules is much more simpler and primitive than having inductive types, fixpoints and match's. For instance, in 2007, Denis Cousineau and Gilles Dowek proved that any pure type system can be encoded in lambda-pi modulo (type-level) rewriting. So, you may be interested in the development of Dedukti, a proof checker for lambda-pi modulo (https://www.rocq.inria.fr/deducteam/Dedukti/).
Frédéric.
They require work to be derived as
well, and the correctness proofs for them are quite similar to that for
sized types. This seems like a matter of preference. Obviously I'm not
neutral in this matter though.
Best,
Cody
Thorsten
Best,
Cody
V.
On Jan 6, 2014, at 6:27 PM, Cody Roux
wrote:
The thing about Coq is that it's very disturbing not to have a
Set-theoretic interpretation where Prop is the set of Booleans {True,
False}. Agda of course doesn't have these qualms, but the fact that
this
issue appears in Coq without use of anything fancy (impredicativity,
etc) makes me still a bit worried. In particular there should be a
Set-theoretic model for Agda where Empty -> Box and Box -are- equal:
with a sufficiently clever interpretation of inductives, I believe I
can
get [[Empty -> Box ]] = [[Box]] = { {} } (where {} is just the empty
set). Can someone with more Agda knowledge try to type the original
problematic term?
Hypothesis Heq : (False -> False) = True.
Fixpoint contradiction (u : True) : False :=
contradiction (
match Heq in (_ = T) return T with
| eq_refl => fun f:False => match f with end
end
On 01/06/2014 06:12 PM, Altenkirch Thorsten wrote:
Hi Maxime,
your postulate seems correct since certainly Empty → Box and Box are
isomorphic and hence equal as a consequence of univalence.
However, I think the definition of loop looks suspicious in the
presence
of proof-relevant equality: if we replace rewrite by an explicit use
of
subst, loop isn't structural recursive anymore. Hence my diagnosis
would
be that rewrite is simply incompatible with univalence.
Cheers,
Thorsten
On 06/01/2014 20:42, "Maxime Dénès"
wrote:
Bingo, Agda seems to have the same problem:
module Termination where
open import Relation.Binary.Core
data Empty : Set where
data Box : Set where
wrap : (Empty → Box) → Box
postulate
iso : (Empty → Box) ≡ Box
loop : Box -> Empty
loop (wrap x) rewrite iso = loop x
gift : Empty → Box
gift ()
bug : Empty
bug = loop (wrap gift)
However, I may be missing something due to my ignorance of Agda. It
may
be well known that the axiom I introduced is inconsistent. Forgive
me if
it is the case.
Maxime.
On 01/06/2014 01:15 PM, Maxime Dénès wrote:
The anti-extensionality bug is indeed related to termination. More
precisely, it is the subterm relation used by the guard checker
which
is not defined quite the right way on dependent pattern matching.
It is not too hard to fix (we have a patch), but doing so without
ruling out any interesting legitimate example (dealing with
recursion
on dependently typed data structures) is more challenging.
I am also curious as to whether Agda is impacted. Let's try it :)
Maxime.
On 01/06/2014 12:59 PM, Altenkirch Thorsten wrote:
Which bug was this?
I only saw the one which allowed you to prove
anti-extensionality?
But
this wasn't related to termination, or?
Thorsten
On 06/01/2014 16:54, "Cody Roux"
wrote:
Nice summary!
On 01/06/2014 08:49 AM, Altenkirch Thorsten wrote:
Agda enforces termination via a termination checker which is
more
flexible but I think less principled than Coq's approach.
That's a bit scary given that there was an inconsistency found
in
the Coq termination checker just a couple of weeks ago :)
BTW, has anyone tried reproducing the bug in Agda?
Cody
This message and any attachment are intended solely for the
addressee
and may contain confidential information. If you have received
this
message in error, please send it back to me, and immediately
delete
it. Please do not use, copy or disclose the information contained
in
this message or in any attachment. Any views or opinions
expressed
by
the author of this email do not necessarily reflect the views of
the
University of Nottingham.
This message has been checked for viruses but the contents of an
may still contain software viruses which could damage your
computer
system, you are advised to perform your own checks. Email
communications with the University of Nottingham may be monitored
as
permitted by UK legislation.
_______________________________________________
Agda mailing list
Agda AT lists.chalmers.se
https://lists.chalmers.se/mailman/listinfo/agda
