- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Why do we have "Prop < Set" ? Why not just "Prop ≤ Set" ?
- Date: Thu, 19 Jan 2017 11:31:30 -0500
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=jonikelee AT gmail.com; spf=Pass smtp.mailfrom=jonikelee AT gmail.com; spf=None smtp.helo=postmaster AT mail-yb0-f194.google.com
- Ironport-phdr: 9a23:xD6mAB3ssPoqJvIIsmDT+DRfVm0co7zxezQtwd8ZsesRLvad9pjvdHbS+e9qxAeQG96Kt7QY0qGG6eigATVGusnR9ihaMdRlbFwst4Y/p0QYGsmLCEn2frbBThcRO4B8bmJj5GyxKkNPGczzNBX4q3y26iMOSF2kbVImbre9JomHhMOukuu25pf7YgNShTP7b6khAg+xqFDzsc8fnYtrLO4VxxrXr31UM7BUwmVpJl+XkhvU6cK5/Zol+CNV7aFyv/VcWLn3KvxrBYdTCy4rZjg4
On 01/19/2017 11:20 AM, Matej Kosik wrote:
Coq < Check (forall x : Set, x) : Set.
Toplevel input, characters 0-32:
Error:
The term "forall x : Set, x" has type "Type@{Set+1}"
while it is expected to have type "Set".
So this is not the counter-example that would show that, when I start "coqtop
-noinit" it would be the case that:
Set not only has all the inhabitants of Prop, but it also has some such
inhabitants, which are not in Prop.
(in which case we could relax "Prop < Set" to "Prop ≤ Set").
Are there such counter-examples?
I think you are missing some implications of what Bruno Barras said here:
The reason why Prop:Set does not hold (although it is consistent in the
default settings of Coq: think of Set as Type(0) and Type(i) as Type(i+1)) is
that Coq allows to make Set impredicative, and we expect this to be an
extension of Coq without the option set (all theorems of Coq without the
option are theorems of Coq with it).
With this option set and Prop:Set, Coq would then contain system U which is
inconsistent.
(this, by the way, would be a great addition to the FAQ).
Note that when -impredicative-set is used, then
succeeds. I think that plus the design constraint on Coq Bruno mentioned above - all theorems without -impredicative-set are theorems with -impredicative-set - might imply that Prop can't bet <= Set even without -impredicative-set.
-- Jonathan
- Re: [Coq-Club] Why do we have "Prop < Set" ? Why not just "Prop ≤ Set" ?, (continued)
- Re: [Coq-Club] Why do we have "Prop < Set" ? Why not just "Prop ≤ Set" ?, Dominique Larchey-Wendling, 01/19/2017
- Re: [Coq-Club] Why do we have "Prop < Set" ? Why not just "Prop ≤ Set" ?, Jacques-Henri Jourdan, 01/19/2017
- Re: [Coq-Club] Why do we have "Prop < Set" ? Why not just "Prop ≤ Set" ?, Théo Zimmermann, 01/18/2017
- Re: [Coq-Club] Why do we have "Prop < Set" ? Why not just "Prop ≤ Set" ?, Bruno Barras, 01/19/2017
- Re: [Coq-Club] Why do we have "Prop < Set" ? Why not just "Prop ≤ Set" ?, Matej Kosik, 01/19/2017
- Re: [Coq-Club] Why do we have "Prop < Set" ? Why not just "Prop ≤ Set" ?, Emilio Jesús Gallego Arias, 01/19/2017
- Re: [Coq-Club] Why do we have "Prop < Set" ? Why not just "Prop ≤ Set" ?, Jonathan Leivent, 01/19/2017
- Re: [Coq-Club] Why do we have "Prop < Set" ? Why not just "Prop ≤ Set" ?, Pierre Courtieu, 01/19/2017
- Re: [Coq-Club] Why do we have "Prop < Set" ? Why not just "Prop ≤ Set" ?, Théo Zimmermann, 01/19/2017
- [Coq-Club] anonymous inductives (was Re: Why do we have "Prop < Set" ? Why not just "Prop ≤ Set" ?), Jonathan Leivent, 01/19/2017
- Re: [Coq-Club] Why do we have "Prop < Set" ? Why not just "Prop ≤ Set" ?, Dan Frumin, 01/20/2017
- Re: [Coq-Club] Why do we have "Prop < Set" ? Why not just "Prop ≤ Set" ?, Pierre Courtieu, 01/20/2017
- Re: [Coq-Club] Why do we have "Prop < Set" ? Why not just "Prop ≤ Set" ?, Jason Gross, 01/20/2017
