- From: Matej Kosik <5764c029b688c1c0d24a2e97cd764f AT gmail.com>
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Why do we have "Prop < Set" ? Why not just "Prop ≤ Set" ?
- Date: Thu, 19 Jan 2017 11:42:30 +0100
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=5764c029b688c1c0d24a2e97cd764f AT gmail.com; spf=Pass smtp.mailfrom=5764c029b688c1c0d24a2e97cd764f AT gmail.com; spf=None smtp.helo=postmaster AT mail-lf0-f50.google.com
- Ironport-phdr: 9a23:VSiQpRI/aVTawQQayNmcpTZWNBhigK39O0sv0rFitYgXI/zxwZ3uMQTl6Ol3ixeRBMOAuq4C17Od6/GoGTRZp83e4DZaKN0EfiRGoPtVtjRoONSCB0z/IayiRA0BN+MGamVY+WqmO1NeAsf0ag6aiHSz6TkPBke3blItdaymUrLV2s+wzqW5/4DZSwROnju0J71ofzusqgCEk8AKjIkqCaEqyxiB9iYXJbhdnTk5LwzDzx2l7Z+8psJqqSkB5PktqJAcX431eq05SfpTCzFwYDN939HiqRSWFVjH3XAbSGhDyhc=
Hi Théo,
Thank you for the reply!
On 01/18/2017 05:39 PM, Théo Zimmermann wrote:
> Hi,
> Disclaimer: there are people so much more qualified than me on this list
> who can answer this question. But as they did not wake up yet (maybe they
> are too engrossed in some POPL presentations) I will
> try to give a few hints.
> My personal, very limited, understanding of the universes was also that
> Prop : Set : Type 1 : Type 2 : ...
> But actually Check Prop : Set. fails both in Coq 8.6 and in your branch. I
> am not sure I understand why.
> Coq < Check Prop:Set.
> Error:
> The term "Prop" has type "Type" while it is expected to have type "Set".
I wonder, why did you think that this might make sense?
(Personally, I do not find the above error message surprising.)
> However, we can see that the constraint allows one to give type Set to
> something of type Prop:
> Coq < Check False : Prop.
> False : Prop
> : Prop
> Coq < Check False : Set.
> False : Set
> : Set
The above behavior is fully consistent with the fact that Prop is declared to
be a subtype of Set.
(Reference Manual, Section 4.4, Point 4).
This makes sense.
> As for weakening the constraint to Prop <= Set do you have any reasons in
> mind?
I think that weakening "Prop < Set" to "Prop ≤ Set" makes sense per se,
unless we have a good reason for those extra restriction.
If there is a good reason for that restriction, we should document it.
If there is no good reason for that restriction:
- it is strange to insist on it
- it inflates the theory
- it creates unnecessary confusion and raises unnecessary questions
> This kind of weakening should allow in particular a constraint resolution
> where Prop = Set. But Prop and Set are
> supposed to be different!
The strangeness of the "Prop < Set" universe depends directly on how you
interpret "_ < _".
If we accept the sloppy definition ("Whatever works, man!"), then there is
nothing strange about this.
If we are fussy about it we can interpret it like:
If X and Y are two universes then "X < Y" means that "Y" has strictly more
inhabitants than "X"
and "X ≤ Y" means that "Y" has at least as
many inhabitants as "X".
In the "fussy interpretation" of "<" and "≤", the restriction "Prop < Set" is
surprising because after starting the toplevel like this:
coqtop -noinit
neither Prop nor Set have any inhabitants and thus it is not the case that
"Prop < Set".
The only thing that we can claim is "Prop ≤ Set".
> Because one is predicative and the other is impredicative.
Are you saying that relaxing "Prop < Set" to "Prop ≤ Set" would prevent us
from keeping impredicativity of Prop and predicativity of Set?
Why?
> And also to help with extraction.
Are you saying that relaxing "Prop < Set" to "Prop ≤ Set" would somehow make
the extraction more difficult?
Why?
> However, even in your branch where you are supposed to have relaxed the
> constraint, it seems that there is still something preventing Set and Prop
> to be considered equal:
> Coq < Check nat : Prop.
>> Check nat : Prop.
> Error:
> The term "nat" has type "Set" while it is expected to have type
> "Prop" (universe inconsistency).
As soon as you an inhabitant of "Set" which is not an inhabitant of "Prop"
(such as "nat"), then "Prop ≠ Set".
In this special case, we can really claim that "Prop < Set" (wrt. to "fussy
interpretation" of "_ < _").
This does not imply that it makes sense in general.
> Théo
> Le mer. 18 janv. 2017 à 17:20, Matej Kosik
> <mailto:5764c029b688c1c0d24a2e97cd764f AT gmail.com>>
> a écrit :
> Hi,
> On 01/18/2017 05:10 PM, Abhishek Anand wrote:
> > Going by the general rule that Ui:Uj if i<j, I suspect that Prop <
> Set would allow the following:
> > Check (Prop:Set)
> > which fails in Coq 8.5pl3.
> AFAIK this:
> Check Prop:Set.
> in all versions of Coq (8.5, 8.6, trunk).
> That makes sense.
> And precisely for that, the current version of the constraint:
> Prop < Set
> does not make sense (to me).
> > So the stronger constraint may allow some new well-typed terms and
> potentially complicate arguments about normalization/consistency etc.
> > -- Abhishek
> > http://www.cs.cornell.edu/~aa755/ <http://www.cs.cornell.edu/~aa755/>
> > On Wed, Jan 18, 2017 at 9:27 AM, Matej Kosik
> <mailto:5764c029b688c1c0d24a2e97cd764f AT gmail.com>>>
> wrote:
> > Hi,
> > I have noticed that in Coq, we have the following universe
> constraint:
> > Prop < Set
> > I am wondering what is the reason for that?
> > Wouldn't
> > Prop <= Set
> > suffice in this case?
> > The code that makes the decision is here:
> > https://github.com/coq/coq/blob/trunk/kernel/uGraph.ml#L716
> <https://github.com/coq/coq/blob/trunk/kernel/uGraph.ml#L716>
> > I wonder whether it is necessary to do:
> > enforce_univ_lt Level.prop Level.set empty
> > as now, or we could simply do
> > enforce_univ_leq Level.prop Level.set empty
> > I've created an experimental branch where I did the change:
> https://github.com/matej-kosik/coq/commit/2fcbb0ced3bc32210ae9fbf4acc40804841c9200
> <https://github.com/matej-kosik/coq/commit/2fcbb0ced3bc32210ae9fbf4acc40804841c9200>
> > ran some tests:
> https://ci.inria.fr/coq/view/coq-contribs/job/coq-contribs/653/console
> <https://ci.inria.fr/coq/view/coq-contribs/job/coq-contribs/653/console>
> > https://ci.inria.fr/coq/view/opam/job/opam-install/22/console
> <https://ci.inria.fr/coq/view/opam/job/opam-install/22/console>
> > and I do not see any breakage but the major question is, would
> this kind of change make Coq inconsistent
> > (enable us to prove False)
> > or not?
> > Thank you in advance for any insight on this.
> > Matej Košík
> Matej Košík
Matej Košík
- Re: [Coq-Club] Why do we have "Prop < Set" ? Why not just "Prop ≤ Set" ?, (continued)
- Re: [Coq-Club] Why do we have "Prop < Set" ? Why not just "Prop ≤ Set" ?, Matej Kosik, 01/19/2017
- Re: [Coq-Club] Why do we have "Prop < Set" ? Why not just "Prop ≤ Set" ?, Guillaume Melquiond, 01/19/2017
- Re: [Coq-Club] Why do we have "Prop < Set" ? Why not just "Prop ≤ Set" ?, Jacques-Henri Jourdan, 01/19/2017
- Re: [Coq-Club] Why do we have "Prop < Set" ? Why not just "Prop ≤ Set" ?, Dominique Larchey-Wendling, 01/19/2017
- Re: [Coq-Club] Why do we have "Prop < Set" ? Why not just "Prop ≤ Set" ?, Théo Zimmermann, 01/18/2017
- Re: [Coq-Club] Why do we have "Prop < Set" ? Why not just "Prop ≤ Set" ?, Bruno Barras, 01/19/2017
- Re: [Coq-Club] Why do we have "Prop < Set" ? Why not just "Prop ≤ Set" ?, Emilio Jesús Gallego Arias, 01/19/2017
- Re: [Coq-Club] Why do we have "Prop < Set" ? Why not just "Prop ≤ Set" ?, Jonathan Leivent, 01/19/2017
- Re: [Coq-Club] Why do we have "Prop < Set" ? Why not just "Prop ≤ Set" ?, Pierre Courtieu, 01/19/2017
- Re: [Coq-Club] Why do we have "Prop < Set" ? Why not just "Prop ≤ Set" ?, Théo Zimmermann, 01/19/2017
- [Coq-Club] anonymous inductives (was Re: Why do we have "Prop < Set" ? Why not just "Prop ≤ Set" ?), Jonathan Leivent, 01/19/2017
- Re: [Coq-Club] Why do we have "Prop < Set" ? Why not just "Prop ≤ Set" ?, Dan Frumin, 01/20/2017
