- From: Matej Kosik <5764c029b688c1c0d24a2e97cd764f AT gmail.com>
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Why do we have "Prop < Set" ? Why not just "Prop ≤ Set" ?
- Date: Thu, 19 Jan 2017 17:25:45 +0100
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=5764c029b688c1c0d24a2e97cd764f AT gmail.com; spf=Pass smtp.mailfrom=5764c029b688c1c0d24a2e97cd764f AT gmail.com; spf=None smtp.helo=postmaster AT mail-lf0-f48.google.com
- Ironport-phdr: 9a23:vaMF1Bd5vqxibyHrctZTLcw7lGMj4u6mDksu8pMizoh2WeGdxc2zZB7h7PlgxGXEQZ/co6odzbGH7+a8ACdfsN7B6ClEK8McEUddyI0/pE8JPo2sMQXDNvnkbig3ToxpdWRO2DWFC3VTA9v0fFbIo3e/vnY4ExT7MhdpdKyuQtaBx5f/6+fn8JrKJg5MmTCVYLVoLRzwox+CmNMRhN5HI7o8yFPqpWBJeKwCmDw2eVnLxUf2uJfg98doqygK5/t7+p8fWqmlIfg2ZbNdBTUidWsy4Zu45lH4UQKT6y5EAS0tmR1SDl2d4Q==
On 01/19/2017 05:20 PM, Matej Kosik wrote:
> Hi Emilio,
> On 01/19/2017 02:02 PM, Emilio Jesús Gallego Arias wrote:
>> Hi Matej,
>> Matej Kosik
>> writes:
>>> after starting the toplevel like this:
>>> coqtop -noinit
>>> neither Prop nor Set have any inhabitants and thus it is not the case
>>> that "Prop < Set".
>>> The only thing that we can claim is "Prop ≤ Set".
>> What do you mean by inhabitant?
> I try to use this word in the same way as it is used by both Coq'Art as
> well as Coq Reference Manual.
> I am not quite sure if it is wise to use this word like this, but that
> question I would not like to open now.
> (we may be creating unnecessary confusion by using words with means that
> can already have more usual denotations)
>> I am not sure what you mean here, but
>> note that `forall x : Prop, x` is an inhabitant of Prop.
> This is a great example! Thank you!
> So, indeed, this is related to what Théo said.
> Even if we do not define any inductive propositions, Prop is inhabited. I
> should have known this but I did not. So thank you!
> Indeed:
> Coq < Check (forall x : Prop, x) : Prop.
> : Prop
> This, still does not invalidated my objection to "Prop < Set" as long as ...
> Check (forall x : Prop, x) : Set.
> : Set
> ... unless, Set has some inhabitants that are not inhabitants of Prop.
> Let's try this:
> Coq < Set Printing Universes.
> Coq < Check (forall x : Prop, x) : Set.
> : Set
> Coq < Check (forall x : Set, x) : Set.
> Toplevel input, characters 0-32:
> Error:
> The term "forall x : Set, x" has type "Type@{Set+1}"
> while it is expected to have type "Set".
> So this is not the counter-example that would show that, when I start
> "coqtop -noinit" it would be the case that:
> Set not only has all the inhabitants of Prop, but it also has some such
> inhabitants, which are not in Prop.
> (in which case we could relax "Prop < Set" to "Prop ≤ Set").
(I meant to say: in which case we *cannot* relax "Prop < Set" to "Prop ≤
Set").
> Are there such counter-examples?
- Re: [Coq-Club] Why do we have "Prop < Set" ? Why not just "Prop ≤ Set" ?, (continued)
- Re: [Coq-Club] Why do we have "Prop < Set" ? Why not just "Prop ≤ Set" ?, Jacques-Henri Jourdan, 01/19/2017
- Re: [Coq-Club] Why do we have "Prop < Set" ? Why not just "Prop ≤ Set" ?, Dominique Larchey-Wendling, 01/19/2017
- Re: [Coq-Club] Why do we have "Prop < Set" ? Why not just "Prop ≤ Set" ?, Théo Zimmermann, 01/18/2017
- Re: [Coq-Club] Why do we have "Prop < Set" ? Why not just "Prop ≤ Set" ?, Bruno Barras, 01/19/2017
- Re: [Coq-Club] Why do we have "Prop < Set" ? Why not just "Prop ≤ Set" ?, Matej Kosik, 01/19/2017
- Re: [Coq-Club] Why do we have "Prop < Set" ? Why not just "Prop ≤ Set" ?, Emilio Jesús Gallego Arias, 01/19/2017
- Re: [Coq-Club] Why do we have "Prop < Set" ? Why not just "Prop ≤ Set" ?, Jonathan Leivent, 01/19/2017
- Re: [Coq-Club] Why do we have "Prop < Set" ? Why not just "Prop ≤ Set" ?, Pierre Courtieu, 01/19/2017
- Re: [Coq-Club] Why do we have "Prop < Set" ? Why not just "Prop ≤ Set" ?, Théo Zimmermann, 01/19/2017
- [Coq-Club] anonymous inductives (was Re: Why do we have "Prop < Set" ? Why not just "Prop ≤ Set" ?), Jonathan Leivent, 01/19/2017
- Re: [Coq-Club] Why do we have "Prop < Set" ? Why not just "Prop ≤ Set" ?, Dan Frumin, 01/20/2017
- Re: [Coq-Club] Why do we have "Prop < Set" ? Why not just "Prop ≤ Set" ?, Pierre Courtieu, 01/20/2017
