Accéder au contenu.
Menu Sympa
starpu-devel - [starpu-devel] Problem in running task size overhead benchmark in starpu
Archives de la liste
Chronologique Discussions
  • To: starpu-devel@inria.fr
  • Subject: [starpu-devel] Problem in running task size overhead benchmark in starpu
  • Date: Thu, 8 Jul 2021 16:34:35 +0530
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=sangeethsimon2@gmail.com; spf=Pass smtp.mailfrom=sangeethsimon2@gmail.com; spf=None smtp.helo=postmaster@mail-yb1-f172.google.com
  • Ironport-hdrordr: A9a23:n+JDb6rOqAXC5EfRgByriB4aV5omeYIsimQD101hICG9E/bo8PxG+c5w6faaskdzZJhNo7C90cq7IE80l6QFg7X5VI3KNGLbUQCTXeRfBOXZslnd8u7FmtK1F50MT0GzMrLN5JFB4/rH3A==
  • Ironport-phdr: A9a23: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
Bonjour a tous,
I am using Starpu-1.3.4 version. I was trying to measure the task size overhead on miriel node using the instructions provided here: https://files.inria.fr/starpu/testing/master/doc/html/CheckListWhenPerformanceAreNotThere.html#CheckTaskSize.
I tried the following:
  1. As per the online manual, I checked here : $STARPU_PATH/lib/starpu/examples/ . But there are not files named tasks_size_overhead.sh here.
  2. tasks_size_overhead.sh named file exist in /home/ssimon/starpu-1.3.4/tests/microbenchs/ . But if I run it, I dont get any output,
These are the three files inside that folder.
tasks_size_overhead_sched.sh
tasks_size_overhead_scheds.sh
I try running
[ssimon@devel03 microbenchs]$ bash tasks_size_overhead_scheds.sh
./microbench.sh: ligne30: ./../../tools/starpu_sched_display: Aucun fichier ou dossier de ce type
This means its looking for something called 'starpu_sched_display' in the tools path and failing when the relative path is wrong?
in tools, we only have 'starpu_sched_display.c'
Now if I try to find it,
[ssimon@devel03 starpu-1.3.4-woCUDA-woFXT]$ find . -type f -name "starpu_sched_display"
./build/tools/.libs/starpu_sched_display
./build/tools/starpu_sched_display
./install/bin/starpu_sched_display
Does this mean we are looking for starpu_sched_display in the wrong place on line 30 within the script ./microbench.sh ??
Am I doing something wrong here?
Is the procedure documented in any of the tutorials?
Merci beaucoup!
Bonne Journee!
Dr. Sangeeth Simon,
Post-Doctoral Researcher,
Team CAGIRE, INRIA,
Pau, Nouvelle-Aquitaine, France
Haut de le page
