Archives de la liste
Re: [starpu-devel] Problem in running task size overhead benchmark in starpu
Chronologique Discussions
- To: Nathalie Furmento <nathalie.furmento@labri.fr>
- Subject: Re: [starpu-devel] Problem in running task size overhead benchmark in starpu
- Date: Thu, 8 Jul 2021 19:34:53 +0530
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=nathalie.furmento@labri.fr; spf=Pass smtp.mailfrom=nathalie.furmento@labri.fr; spf=None smtp.helo=postmaster@v-zimmta03.u-bordeaux.fr
- Ironport-hdrordr: A9a23:NwfpdKOf2C1Qa8BcT7r155DYdb4zR+YMi2TDt3oBLiC9E/bo3PxG+c5rqSMc5wxhL03I9erwTJVoBEmsgKKdgrNhTotKPjOWzldARbsKheCJol2QfVyGh5YtrtYbAtVD4Z/LfCpHZXCW2mWF+yxJ+rS62Zuln+vY0jNIQRtxY69tqydVYzz1LmRMSBNLAod8KZz03KR6TlGbCD0qh6qAdzE4dtmGj+KOvpPraxwLCnccmUazZPCTmcDH+tqjr2gjuv90sMYfGKH+4nzEz5TmiOujwhvQk1fO44hb3Pvto+EzTvCku4wvMCzljgvtXoh7RLGY1QpF7N1HBWxa8+UkuS1QWvhb2jfqZ2mw5SHm3RLtuQxeiUMK12Xo5UfLkIjCXTo/Bo57iZhEdwax0TtsgO1B
- Resent-date: Fri, 9 Jul 2021 09:12:10 +0200
- Resent-from: Nathalie Furmento <nathalie.furmento@labri.fr>
- Resent-message-id: <20210709071210.GB11323@adrets>
- Resent-to: starpu-devel@inria.fr
I rechecked, the script indeed should be installed in $STARPU_PATH/lib/starpu/examples/
could you please send your config.log file to check what went wrong ?
and, you should make sure to use the documentation of the version you are using (for this section, there is no difference).
https://files.inria.fr/starpu/testing/master/doc/html/CheckListWhenPerformanceAreNotThere.html#CheckTaskSize is for the master version
for the other versions, the link are available here https://files.inria.fr/starpu/
Cheers,
Nathalie
On 08/07/2021 13:32, Nathalie Furmento wrote:
Hello,
The script you need to run should be in the build directory.
build/tests/microbenchs/tasks_size_overhead.sh
nfurmento@conan:~/softs/starpu/starpu/master/build$ ./tests/microbenchs/tasks_size_overhead.sh
[starpu][starpu_initialize] Warning: StarPU was configured with --enable-debug (-O0), and is thus not optimized
[starpu][starpu_initialize] Warning: StarPU was configured with --enable-spinlock-check, which slows down a bit
[starpu][starpu_initialize] Warning: StarPU was configured with --enable-verbose, which slows down a bit
[starpu][_starpu_opencl_init] Initialising OpenCL
[starpu][_starpu_opencl_init] Platforms detected: 1
[starpu][_starpu_opencl_init] CPU device type: not requested
[starpu][_starpu_opencl_init] GPU device type: requested
[starpu][_starpu_opencl_init] Accelerator device type: requested
[starpu][_starpu_opencl_init] Platform: NVIDIA CUDA - NVIDIA Corporation
[starpu][_starpu_opencl_init] 3 devices detected
Cheers,
Nathalie
On 08/07/2021 13:04, Sangeeth Simon wrote:
Bonjour a tous,I am using Starpu-1.3.4 version. I was trying to measure the task size overhead on miriel node using the instructions provided here: https://files.inria.fr/starpu/testing/master/doc/html/CheckListWhenPerformanceAreNotThere.html#CheckTaskSize.
I tried the following:
- As per the online manual, I checked here : $STARPU_PATH/lib/starpu/examples/ . But there are not files named tasks_size_overhead.sh here.
- tasks_size_overhead.sh named file exist in /home/ssimon/starpu-1.3.4/tests/microbenchs/ . But if I run it, I dont get any output,
These are the three files inside that folder.
tasks_size_overhead_sched.sh
tasks_size_overhead_scheds.sh
tasks_size_overhead.shI try running
[ssimon@devel03 microbenchs]$ bash tasks_size_overhead_scheds.sh
./microbench.sh: ligne30: ./../../tools/starpu_sched_display: Aucun fichier ou dossier de ce typeThis means its looking for something called 'starpu_sched_display' in the tools path and failing when the relative path is wrong?
in tools, we only have 'starpu_sched_display.c'
Now if I try to find it,
[ssimon@devel03 starpu-1.3.4-woCUDA-woFXT]$ find . -type f -name "starpu_sched_display"
./build/tools/.libs/starpu_sched_display
./build/tools/starpu_sched_display
./install/bin/starpu_sched_display
Does this mean we are looking for starpu_sched_display in the wrong place on line 30 within the script ./microbench.sh ??
Am I doing something wrong here?
Is the procedure documented in any of the tutorials?
Merci beaucoup!
Bonne Journee!
Dr. Sangeeth Simon,
Post-Doctoral Researcher,
Team CAGIRE, INRIA,
Pau, Nouvelle-Aquitaine, France
-- Dr Nathalie Furmento Ingénieure de recherche CNRS http://www.labri.fr/~furmento/ LaBRI - Université Bordeaux
config.log
Description: Binary data
- [starpu-devel] Problem in running task size overhead benchmark in starpu, Sangeeth Simon, 08/07/2021
- Re: [starpu-devel] Problem in running task size overhead benchmark in starpu, Nathalie Furmento, 08/07/2021
- Re: [starpu-devel] Problem in running task size overhead benchmark in starpu, Sangeeth Simon, 09/07/2021
- Re: [starpu-devel] Problem in running task size overhead benchmark in starpu, Samuel Thibault, 09/07/2021
- Re: [starpu-devel] Problem in running task size overhead benchmark in starpu, Nathalie Furmento, 09/07/2021
