Accéder au contenu.
Menu Sympa
starpu-devel - Re: [starpu-devel] Problem in running task size overhead benchmark in starpu
Archives de la liste
Chronologique Discussions
  • To: Nathalie Furmento <nathalie.furmento@labri.fr>
  • Cc: starpu-devel@inria.fr
  • Subject: Re: [starpu-devel] Problem in running task size overhead benchmark in starpu
  • Date: Fri, 9 Jul 2021 14:01:08 +0530
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=sangeethsimon2@gmail.com; spf=Pass smtp.mailfrom=sangeethsimon2@gmail.com; spf=None smtp.helo=postmaster@mail-yb1-f172.google.com
  • Ironport-hdrordr: A9a23:gzwTP6yxdiCqS/jfFJTPKrPwJr1zdoMgy1knxilNoG9uA6qlfqGV7ZMmPHDP+VQssR0b+OxoW5PwJU80l6QFgrX5VI3KNGKN1QfGEGgI1+vfKlPbdREWutQtsJuJJMNFeaTNMWQ=
  • Ironport-phdr: A9a23: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
Bonjour Nathalie,
Yes, 'make install' was done. I am attaching the script I use for installing starpu. Please verify.
Bonne Journee!
On Fri, Jul 9, 2021 at 12:46 AM Nathalie Furmento <nathalie.furmento@labri.fr> wrote:
Did you run make install ? That's the step which is creating the directory $STARPU_PATH/lib/starpu/examples/ ($STARPU_PATH being the directory given as a parameter to --prefix)
(please keep starpu-devel as a recipient to your reply)
Cheers,
Nathalie
On 08/07/2021 16:04, Sangeeth Simon wrote:
Bonjour Nathalie,
Thank you for your reply. I was able to produce the results as per your suggestion.
I dont see this path $STARPU_PATH/lib/starpu/examples/ in my directory.
I am attaching the config.log file as requested by you:
On Thu, Jul 8, 2021 at 5:56 PM Nathalie Furmento <nathalie.furmento@labri.fr> wrote:
I rechecked, the script indeed should be installed in $STARPU_PATH/lib/starpu/examples/
could you please send your config.log file to check what went wrong ?
and, you should make sure to use the documentation of the version you are using (for this section, there is no difference).
for the other versions, the link are available here https://files.inria.fr/starpu/
Cheers,
Nathalie
On 08/07/2021 13:32, Nathalie Furmento wrote:
Hello,
The script you need to run should be in the  build directory.
build/tests/microbenchs/tasks_size_overhead.sh
nfurmento@conan:~/softs/starpu/starpu/master/build$ ./tests/microbenchs/tasks_size_overhead.sh
[starpu][starpu_initialize] Warning: StarPU was configured with --enable-debug (-O0), and is thus not optimized
[starpu][starpu_initialize] Warning: StarPU was configured with --enable-spinlock-check, which slows down a bit
[starpu][starpu_initialize] Warning: StarPU was configured with --enable-verbose, which slows down a bit
[starpu][_starpu_opencl_init] Initialising OpenCL
[starpu][_starpu_opencl_init] Platforms detected: 1
[starpu][_starpu_opencl_init] CPU device type: not requested
[starpu][_starpu_opencl_init] GPU device type: requested
[starpu][_starpu_opencl_init] Accelerator device type: requested
[starpu][_starpu_opencl_init] Platform: NVIDIA CUDA - NVIDIA Corporation
[starpu][_starpu_opencl_init]   3 devices detected
Cheers,
Nathalie
On 08/07/2021 13:04, Sangeeth Simon wrote:
Bonjour a tous,
I am using Starpu-1.3.4 version. I was trying to measure the task size overhead on miriel node using the instructions provided here: https://files.inria.fr/starpu/testing/master/doc/html/CheckListWhenPerformanceAreNotThere.html#CheckTaskSize.
I tried the following:
  1. As per the online manual, I checked here : $STARPU_PATH/lib/starpu/examples/ . But there are not files named tasks_size_overhead.sh here.
  2. tasks_size_overhead.sh named file exist in /home/ssimon/starpu-1.3.4/tests/microbenchs/ . But if I run it, I dont get any output,
These are the three files inside that folder.
tasks_size_overhead_sched.sh
tasks_size_overhead_scheds.sh
I try running
[ssimon@devel03 microbenchs]$ bash tasks_size_overhead_scheds.sh
./microbench.sh: ligne30: ./../../tools/starpu_sched_display: Aucun fichier ou dossier de ce type
This means its looking for something called 'starpu_sched_display' in the tools path and failing when the relative path is wrong?
in tools, we only have 'starpu_sched_display.c'
Now if I try to find it,
[ssimon@devel03 starpu-1.3.4-woCUDA-woFXT]$ find . -type f -name "starpu_sched_display"
./build/tools/.libs/starpu_sched_display
./build/tools/starpu_sched_display
./install/bin/starpu_sched_display
Does this mean we are looking for starpu_sched_display in the wrong place on line 30 within the script ./microbench.sh ??
Am I doing something wrong here?
Is the procedure documented in any of the tutorials?
Merci beaucoup!
Bonne Journee!
Dr. Sangeeth Simon,
Post-Doctoral Researcher,
Team CAGIRE, INRIA,
Pau, Nouvelle-Aquitaine, France
Dr Nathalie Furmento               Ingénieure de recherche CNRS
http://www.labri.fr/~furmento/     LaBRI - Université Bordeaux
Dr. Sangeeth Simon,
Team CAGIRE, INRIA,
Dr. Sangeeth Simon,
Team CAGIRE, INRIA,
Attachment: script_install_starpu.sh
Description: application/shellscript
Haut de le page
