Archives de la liste
Re: [starpu-devel] Problem in running task size overhead benchmark in starpu
Chronologique Discussions
- From: Nathalie Furmento <nathalie.furmento@labri.fr>
- To: Sangeeth Simon <sangeethsimon2@gmail.com>, starpu-devel@inria.fr
- Subject: Re: [starpu-devel] Problem in running task size overhead benchmark in starpu
- Date: Thu, 8 Jul 2021 14:26:49 +0200
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=nathalie.furmento@labri.fr; spf=Pass smtp.mailfrom=nathalie.furmento@labri.fr; spf=None smtp.helo=postmaster@v-zimmta03.u-bordeaux.fr
https://files.inria.fr/starpu/testing/master/doc/html/CheckListWhenPerformanceAreNotThere.html#CheckTaskSize is for the master version
[starpu][starpu_initialize] Warning: StarPU was configured with --enable-debug (-O0), and is thus not optimized
[starpu][starpu_initialize] Warning: StarPU was configured with --enable-spinlock-check, which slows down a bit
[starpu][starpu_initialize] Warning: StarPU was configured with --enable-verbose, which slows down a bit
[starpu][_starpu_opencl_init] Initialising OpenCL
[starpu][_starpu_opencl_init] Platforms detected: 1
[starpu][_starpu_opencl_init] CPU device type: not requested
[starpu][_starpu_opencl_init] GPU device type: requested
[starpu][_starpu_opencl_init] Accelerator device type: requested
[starpu][_starpu_opencl_init] Platform: NVIDIA CUDA - NVIDIA Corporation
[starpu][_starpu_opencl_init] 3 devices detected
Cheers,
Nathalie
I tried the following:
- As per the online manual, I checked here : $STARPU_PATH/lib/starpu/examples/ . But there are not files named tasks_size_overhead.sh here.
- tasks_size_overhead.sh named file exist in /home/ssimon/starpu-1.3.4/tests/microbenchs/ . But if I run it, I dont get any output,
These are the three files inside that folder.
tasks_size_overhead_sched.sh
tasks_size_overhead_scheds.sh
I try running
[ssimon@devel03 microbenchs]$ bash
./microbench.sh: ligne30:
./../../tools/starpu_sched_display:
Aucun fichier ou dossier de ce type
This means its looking for something
called 'starpu_sched_display' in the
tools path and failing when the relative
path is wrong?
in tools, we only have 'starpu_sched_display.c'
Now if I try to find it,
[ssimon@devel03
starpu-1.3.4-woCUDA-woFXT]$ find . -type
f -name "starpu_sched_display"
./build/tools/.libs/starpu_sched_display
./build/tools/starpu_sched_display
./install/bin/starpu_sched_display
-- Dr Nathalie Furmento Ingénieure de recherche CNRS http://www.labri.fr/~furmento/ LaBRI - Université Bordeaux
- [starpu-devel] Problem in running task size overhead benchmark in starpu, Sangeeth Simon, 08/07/2021
- Re: [starpu-devel] Problem in running task size overhead benchmark in starpu, Nathalie Furmento, 08/07/2021
- Re: [starpu-devel] Problem in running task size overhead benchmark in starpu, Sangeeth Simon, 09/07/2021
- Re: [starpu-devel] Problem in running task size overhead benchmark in starpu, Samuel Thibault, 09/07/2021
- Re: [starpu-devel] Problem in running task size overhead benchmark in starpu, Nathalie Furmento, 09/07/2021
