Archives de la liste
Re: [starpu-devel] Problem in running task size overhead benchmark in starpu
Chronologique Discussions
- From: Nathalie Furmento <nathalie.furmento@labri.fr>
- To: Sangeeth Simon <sangeethsimon2@gmail.com>
- Cc: starpu-devel@inria.fr
- Subject: Re: [starpu-devel] Problem in running task size overhead benchmark in starpu
- Date: Fri, 9 Jul 2021 10:41:04 +0200
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=nathalie.furmento@labri.fr; spf=Pass smtp.mailfrom=nathalie.furmento@labri.fr; spf=None smtp.helo=postmaster@v-zimmta03.u-bordeaux.fr
- Ironport-hdrordr: A9a23:6lufqa1CZHs6EkbcQcrITQqjBLEkLtp133Aq2lEZdPU1SL37qynApp4mPHPP5Qr5HUtPpTniAtjifZq/z/FICOAqVN/IYOClggqVxepZjbcKtgeQfREWgdQtspuIHZITNDSJNykfsS+s2njcL+od
I am attaching the config.log file as requested by you:I dont see this path $STARPU_PATH/lib/starpu/examples/ in my directory.Bonjour Nathalie,
Thank you for your reply. I was able to produce the results as per your suggestion.
On Thu, Jul 8, 2021 at 5:56 PM Nathalie Furmento <nathalie.furmento@labri.fr> wrote:
I rechecked, the script indeed should be installed in $STARPU_PATH/lib/starpu/examples/
could you please send your config.log file to check what went wrong ?
and, you should make sure to use the documentation of the version you are using (for this section, there is no difference).
https://files.inria.fr/starpu/testing/master/doc/html/CheckListWhenPerformanceAreNotThere.html#CheckTaskSize is for the master version
for the other versions, the link are available here https://files.inria.fr/starpu/
Cheers,
Nathalie
On 08/07/2021 13:32, Nathalie Furmento wrote:
Hello,
The script you need to run should be in the build directory.
build/tests/microbenchs/tasks_size_overhead.sh
nfurmento@conan:~/softs/starpu/starpu/master/build$ ./tests/microbenchs/tasks_size_overhead.sh
[starpu][starpu_initialize] Warning: StarPU was configured with --enable-debug (-O0), and is thus not optimized
[starpu][starpu_initialize] Warning: StarPU was configured with --enable-spinlock-check, which slows down a bit
[starpu][starpu_initialize] Warning: StarPU was configured with --enable-verbose, which slows down a bit
[starpu][_starpu_opencl_init] Initialising OpenCL
[starpu][_starpu_opencl_init] Platforms detected: 1
[starpu][_starpu_opencl_init] CPU device type: not requested
[starpu][_starpu_opencl_init] GPU device type: requested
[starpu][_starpu_opencl_init] Accelerator device type: requested
[starpu][_starpu_opencl_init] Platform: NVIDIA CUDA - NVIDIA Corporation
[starpu][_starpu_opencl_init] 3 devices detected
Cheers,
Nathalie
On 08/07/2021 13:04, Sangeeth Simon wrote:
Bonjour a tous,I am using Starpu-1.3.4 version. I was trying to measure the task size overhead on miriel node using the instructions provided here: https://files.inria.fr/starpu/testing/master/doc/html/CheckListWhenPerformanceAreNotThere.html#CheckTaskSize.
I tried the following:
- As per the online manual, I checked here : $STARPU_PATH/lib/starpu/examples/ . But there are not files named tasks_size_overhead.sh here.
- tasks_size_overhead.sh named file exist in /home/ssimon/starpu-1.3.4/tests/microbenchs/ . But if I run it, I dont get any output,
These are the three files inside that folder.
tasks_size_overhead_sched.sh
tasks_size_overhead_scheds.sh
I try running
[ssimon@devel03
microbenchs]$ bash
./microbench.sh:
ligne30:
./../../tools/starpu_sched_display:
Aucun fichier ou dossier
de ce type
This means its looking
for something called
'starpu_sched_display'
in the tools path and
failing when the
relative path is wrong?
in tools, we only have 'starpu_sched_display.c'
Now if I try to find
it,
[ssimon@devel03
starpu-1.3.4-woCUDA-woFXT]$
find . -type f -name
"starpu_sched_display"
./build/tools/.libs/starpu_sched_display
./build/tools/starpu_sched_display
./install/bin/starpu_sched_display
-- Dr Nathalie Furmento Ingénieure de recherche CNRS http://www.labri.fr/~furmento/ LaBRI - Université Bordeaux
- [starpu-devel] Problem in running task size overhead benchmark in starpu, Sangeeth Simon, 08/07/2021
- Re: [starpu-devel] Problem in running task size overhead benchmark in starpu, Nathalie Furmento, 08/07/2021
- Re: [starpu-devel] Problem in running task size overhead benchmark in starpu, Sangeeth Simon, 09/07/2021
- Re: [starpu-devel] Problem in running task size overhead benchmark in starpu, Samuel Thibault, 09/07/2021
- Re: [starpu-devel] Problem in running task size overhead benchmark in starpu, Nathalie Furmento, 09/07/2021
