Accéder au contenu.
Menu Sympa
starpu-devel - Re: [starpu-devel] Problem in running task size overhead benchmark in starpu
Archives de la liste
Chronologique Discussions
  • From: Nathalie Furmento <nathalie.furmento@labri.fr>
  • To: Sangeeth Simon <sangeethsimon2@gmail.com>, starpu-devel@inria.fr
  • Subject: Re: [starpu-devel] Problem in running task size overhead benchmark in starpu
  • Date: Thu, 8 Jul 2021 21:16:54 +0200
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=nathalie.furmento@labri.fr; spf=Pass smtp.mailfrom=nathalie.furmento@labri.fr; spf=None smtp.helo=postmaster@v-zimmta03.u-bordeaux.fr
  • Ironport-hdrordr: A9a23:SpmI4aswgqPLspQIbdfzt4qI7skDktV00zEX/kB9WHVpm+ij5qSTdZMgpG/JYVcqKQIdcL+7VpVoK0mwyXdK2/hiAV7PZmnbUIXBFvAf0WPNqweQZREW3NQtr5uJSsBFeaLN5bITt7eK3ODAKadc/DDlytHMuQ699RZQpFpRGtpdBm5CY27xfiJLrSZ9dO8E/fGnl6x6TlSbCBcqh4iAdxs4tymqnayzqLvWJToPBxsi4A7LpSqw87jkHxXd9gp2aUIp/V+smVK16zARi5/Ij82G
Did you run make install ? That's the step which is creating the directory $STARPU_PATH/lib/starpu/examples/ ($STARPU_PATH being the directory given as a parameter to --prefix)
(please keep starpu-devel as a recipient to your reply)
Cheers,
Nathalie
On 08/07/2021 16:04, Sangeeth Simon wrote:
Bonjour Nathalie,
Thank you for your reply. I was able to produce the results as per your suggestion.
I dont see this path $STARPU_PATH/lib/starpu/examples/ in my directory.
I am attaching the config.log file as requested by you:
On Thu, Jul 8, 2021 at 5:56 PM Nathalie Furmento <nathalie.furmento@labri.fr> wrote:
I rechecked, the script indeed should be installed in $STARPU_PATH/lib/starpu/examples/
could you please send your config.log file to check what went wrong ?
and, you should make sure to use the documentation of the version you are using (for this section, there is no difference).
https://files.inria.fr/starpu/testing/master/doc/html/CheckListWhenPerformanceAreNotThere.html#CheckTaskSize is for the master version
for the other versions, the link are available here https://files.inria.fr/starpu/
Cheers,
Nathalie
On 08/07/2021 13:32, Nathalie Furmento wrote:
Hello,
The script you need to run should be in the  build directory.
build/tests/microbenchs/tasks_size_overhead.sh
nfurmento@conan:~/softs/starpu/starpu/master/build$ ./tests/microbenchs/tasks_size_overhead.sh
[starpu][starpu_initialize] Warning: StarPU was configured with --enable-debug (-O0), and is thus not optimized
[starpu][starpu_initialize] Warning: StarPU was configured with --enable-spinlock-check, which slows down a bit
[starpu][starpu_initialize] Warning: StarPU was configured with --enable-verbose, which slows down a bit
[starpu][_starpu_opencl_init] Initialising OpenCL
[starpu][_starpu_opencl_init] Platforms detected: 1
[starpu][_starpu_opencl_init] CPU device type: not requested
[starpu][_starpu_opencl_init] GPU device type: requested
[starpu][_starpu_opencl_init] Accelerator device type: requested
[starpu][_starpu_opencl_init] Platform: NVIDIA CUDA - NVIDIA Corporation
[starpu][_starpu_opencl_init]   3 devices detected
Cheers,
Nathalie
On 08/07/2021 13:04, Sangeeth Simon wrote:
Bonjour a tous,
I am using Starpu-1.3.4 version. I was trying to measure the task size overhead on miriel node using the instructions provided here: https://files.inria.fr/starpu/testing/master/doc/html/CheckListWhenPerformanceAreNotThere.html#CheckTaskSize.
I tried the following:
  1. As per the online manual, I checked here : $STARPU_PATH/lib/starpu/examples/ . But there are not files named tasks_size_overhead.sh here.
  2. tasks_size_overhead.sh named file exist in /home/ssimon/starpu-1.3.4/tests/microbenchs/ . But if I run it, I dont get any output,
These are the three files inside that folder.
tasks_size_overhead_sched.sh
tasks_size_overhead_scheds.sh
I try running
[ssimon@devel03 microbenchs]$ bash tasks_size_overhead_scheds.sh
./microbench.sh: ligne30: ./../../tools/starpu_sched_display: Aucun fichier ou dossier de ce type
This means its looking for something called 'starpu_sched_display' in the tools path and failing when the relative path is wrong?
in tools, we only have 'starpu_sched_display.c'
Now if I try to find it,
[ssimon@devel03 starpu-1.3.4-woCUDA-woFXT]$ find . -type f -name "starpu_sched_display"
./build/tools/.libs/starpu_sched_display
./build/tools/starpu_sched_display
./install/bin/starpu_sched_display
Does this mean we are looking for starpu_sched_display in the wrong place on line 30 within the script ./microbench.sh ??
Am I doing something wrong here?
Is the procedure documented in any of the tutorials?
Merci beaucoup!
Bonne Journee!
Dr. Sangeeth Simon,
Post-Doctoral Researcher,
Team CAGIRE, INRIA,
Pau, Nouvelle-Aquitaine, France
Dr Nathalie Furmento               Ingénieure de recherche CNRS
http://www.labri.fr/~furmento/     LaBRI - Université Bordeaux
Dr. Sangeeth Simon,
Team CAGIRE, INRIA,
Haut de le page
