Archives de la liste
Re: [starpu-devel] Problem in running task size overhead benchmark in starpu
Chronologique Discussions
- From: Nathalie Furmento <nathalie.furmento@labri.fr>
- To: Sangeeth Simon <sangeethsimon2@gmail.com>, starpu-devel@inria.fr
- Subject: Re: [starpu-devel] Problem in running task size overhead benchmark in starpu
- Date: Thu, 8 Jul 2021 13:32:12 +0200
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=nathalie.furmento@labri.fr; spf=Pass smtp.mailfrom=nathalie.furmento@labri.fr; spf=None smtp.helo=postmaster@v-zimmta03.u-bordeaux.fr
- Ironport-hdrordr: A9a23:Z3qfzKGFRxWHcVX2pLqFT5HXdLJyesId70hD6qkvc202TiXIrbHMoB1E73/JYW4qKQ0dcKO7Sda9qBLnhN5ICOYqTM2ftWXdyQyVxeJZnMjfKl/balDDH4dmvM8MH8cRaayUfDxHZK7BkVSF+r0bsaC6GdWT9JzjJgBWPHlXgs9bnmFE4nDwKCdLrNUvP+tnKLOsoupBuh+nf21OB/7ROlA1G8z44/HbnpPvZhALQzQ97hOVsD+u4LnmVzCFwxY3SVp0sPUf2FmAtza8yrSosvm9xBOZ/XTU9Y5qlNzozcYGLNCQi/ISNi7nhm+TFcFcsvy5zXQISdOUmRAXeer30k4d1gNImivsl1SO0FzQMs/boW0TAjHZuAWlaDDY0LLErXoBert8bMRiA0fkAgMbzaNBOK4n5RPri7NHSRzHhyjz/N7OSlVjkVe1u2MrlaoJg2VYSpZ2Us4ckWUzxjIeLH47JlO21GnnKpgmMOjMoPJNNV+KZXHQuWdihNSqQ3QoBx+DBkwPoNac3TRalG1wixJw/r1Qol4QsJYmD5VU7eXNNapl0LlIU88NdKp4QOMMW9G+BGDBSQ/FdGiSPVPkHqcaPG+lke+53F0fjNvaDaDgDKFC06gpdWko9FLaV3iefvFm7ac7uiwlGl/NKQgF4vsukaRRq/nnTqHuNGmbU1Awm8GxpvkBDsizYYfCBK5r
[starpu][starpu_initialize] Warning: StarPU was configured with --enable-debug (-O0), and is thus not optimized
[starpu][starpu_initialize] Warning: StarPU was configured with --enable-spinlock-check, which slows down a bit
[starpu][starpu_initialize] Warning: StarPU was configured with --enable-verbose, which slows down a bit
[starpu][_starpu_opencl_init] Initialising OpenCL
[starpu][_starpu_opencl_init] Platforms detected: 1
[starpu][_starpu_opencl_init] CPU device type: not requested
[starpu][_starpu_opencl_init] GPU device type: requested
[starpu][_starpu_opencl_init] Accelerator device type: requested
[starpu][_starpu_opencl_init] Platform: NVIDIA CUDA - NVIDIA Corporation
[starpu][_starpu_opencl_init] 3 devices detected
Cheers,
Nathalie
I tried the following:
- As per the online manual, I checked here : $STARPU_PATH/lib/starpu/examples/ . But there are not files named tasks_size_overhead.sh here.
- tasks_size_overhead.sh named file exist in /home/ssimon/starpu-1.3.4/tests/microbenchs/ . But if I run it, I dont get any output,
These are the three files inside that folder.
tasks_size_overhead_sched.sh
tasks_size_overhead_scheds.sh
I try running
[ssimon@devel03 microbenchs]$ bash
./microbench.sh: ligne30:
./../../tools/starpu_sched_display: Aucun
fichier ou dossier de ce type
This means its looking for something
called 'starpu_sched_display' in the tools
path and failing when the relative path is
wrong?
in tools, we only have 'starpu_sched_display.c'
Now if I try to find it,
[ssimon@devel03
starpu-1.3.4-woCUDA-woFXT]$ find . -type f
-name "starpu_sched_display"
./build/tools/.libs/starpu_sched_display
./build/tools/starpu_sched_display
./install/bin/starpu_sched_display
-- Dr Nathalie Furmento Ingénieure de recherche CNRS http://www.labri.fr/~furmento/ LaBRI - Université Bordeaux
- [starpu-devel] Problem in running task size overhead benchmark in starpu, Sangeeth Simon, 08/07/2021
- Re: [starpu-devel] Problem in running task size overhead benchmark in starpu, Nathalie Furmento, 08/07/2021
- Re: [starpu-devel] Problem in running task size overhead benchmark in starpu, Sangeeth Simon, 09/07/2021
- Re: [starpu-devel] Problem in running task size overhead benchmark in starpu, Samuel Thibault, 09/07/2021
- Re: [starpu-devel] Problem in running task size overhead benchmark in starpu, Nathalie Furmento, 09/07/2021
