Archives de la liste
Re: [starpu-devel] Problem in running task size overhead benchmark in starpu
Chronologique Discussions
- To: Sangeeth Simon <sangeethsimon2@gmail.com>
- Cc: Nathalie Furmento <nathalie.furmento@labri.fr>, starpu-devel@inria.fr
- Subject: Re: [starpu-devel] Problem in running task size overhead benchmark in starpu
- Date: Fri, 9 Jul 2021 10:37:42 +0200
- Ironport-hdrordr: A9a23:9DJbV6DpRV1wrpLlHemK55DYdb4zR+YMi2TDtnocdfUxSKelfq+V88jzuSWbtN9pYgBFpTnjAsm9qALnlKKdiLN5Vd3OYOCMghrKEGgN1/qY/xTQXwH46+5BxeNBXsFFeafN5VURt7eZ3OG1eexQpuVu+sqT9IDjJ3gGd3AOV0i41XYBNu9MKDwPeDV7
- Organization: I am not organized
Hello,
Sangeeth Simon, le ven. 09 juil. 2021 14:01:08 +0530, a ecrit:
> Yes, 'make install' was done.
Did it complete successfully? Could you attach the log of the make install
command?
Samuel
> I am attaching the script I use for installing
> starpu. Please verify.
> Bonne Journee!
> On Fri, Jul 9, 2021 at 12:46 AM Nathalie Furmento <[1]
> nathalie.furmento@labri.fr> wrote:
> Did you run make install ? That's the step which is creating the
> directory
> $STARPU_PATH/lib/starpu/examples/ ($STARPU_PATH being the directory
> given
> as a parameter to --prefix)
> (please keep starpu-devel as a recipient to your reply)
> Cheers,
> Nathalie
> On 08/07/2021 16:04, Sangeeth Simon wrote:
> Bonjour Nathalie,
> Thank you for your reply. I was able to produce the results as per
> your
> suggestion.
> I dont see this path $STARPU_PATH/lib/starpu/examples/ in my
> directory.
> I am attaching the config.log file as requested by you:
> On Thu, Jul 8, 2021 at 5:56 PM Nathalie Furmento <[2]
> I rechecked, the script indeed should be installed in
> $STARPU_PATH/
> could you please send your config.log file to check what went
> wrong
> and, you should make sure to use the documentation of the
> version
> you are using (for this section, there is no difference).
> [3]https://files.inria.fr/starpu/testing/master/doc/html/
> CheckListWhenPerformanceAreNotThere.html#CheckTaskSize is for
> the
> master version
> for the other versions, the link are available here [4]https://
> Cheers,
> Nathalie
> On 08/07/2021 13:32, Nathalie Furmento wrote:
> Hello,
> The script you need to run should be in the build
> directory.
> build/tests/microbenchs/tasks_size_overhead.sh
> nfurmento@conan:~/softs/starpu/starpu/master/build$ ./tests/
> [starpu][starpu_initialize] Warning: StarPU was configured
> with
> --enable-debug (-O0), and is thus not optimized
> with
> --enable-spinlock-check, which slows down a bit
> with
> --enable-verbose, which slows down a bit
> [starpu][_starpu_opencl_init] Initialising OpenCL
> [starpu][_starpu_opencl_init] Platforms detected: 1
> [starpu][_starpu_opencl_init] CPU device type: not requested
> [starpu][_starpu_opencl_init] GPU device type: requested
> [starpu][_starpu_opencl_init] Accelerator device type:
> requested
> [starpu][_starpu_opencl_init] Platform: NVIDIA CUDA - NVIDIA
> Corporation
> [starpu][_starpu_opencl_init] 3 devices detected
> Cheers,
> Nathalie
> On 08/07/2021 13:04, Sangeeth Simon wrote:
> Bonjour a tous,
> I am using Starpu-1.3.4 version. I was trying to measure
> the task size overhead on miriel node using the
> instructions provided here: [5]https://files.inria.fr/
> CheckListWhenPerformanceAreNotThere.html#CheckTaskSize.
> I tried the following:
> 1. As per the online manual, I checked here :
> $STARPU_PATH
> /lib/starpu/examples/ . But there are not files
> named
> tasks_size_overhead.sh here.
> 2. tasks_size_overhead.sh named file exist in
> /home/ssimon
> /starpu-1.3.4/tests/microbenchs/ . But if I run it,
> I
> dont get any output,
> These are the three files inside that folder.
> tasks_size_overhead_sched.sh
> tasks_size_overhead_scheds.sh
> I try running
> [ssimon@devel03 microbenchs]$ bash
> ./microbench.sh: ligne30: ./../../tools/
> starpu_sched_display: Aucun fichier ou dossier de ce
> type
> This means its looking for something called
> 'starpu_sched_display' in the tools path and failing
> when
> the relative path is wrong?
> in tools, we only have 'starpu_sched_display.c'
> Now if I try to find it,
> [ssimon@devel03 starpu-1.3.4-woCUDA-woFXT]$ find .
> -type f
> -name "starpu_sched_display"
> ./build/tools/.libs/starpu_sched_display
> ./build/tools/starpu_sched_display
> ./install/bin/starpu_sched_display
> Does this mean we are looking for starpu_sched_display
> in
> the wrong place on line 30 within the script ./
> microbench.sh ??
> Am I doing something wrong here?
> Is the procedure documented in any of the tutorials?
> Merci beaucoup!
> Bonne Journee!
> Dr. Sangeeth Simon,
> Post-Doctoral Researcher,
> Team CAGIRE, INRIA,
> Pau, Nouvelle-Aquitaine, France
> Dr Nathalie Furmento Ingénieure de recherche
> CNRS
> [6]http://www.labri.fr/~furmento/ LaBRI - Université
> Bordeaux
> Dr Nathalie Furmento Ingénieure de recherche CNRS
> [7]http://www.labri.fr/~furmento/ LaBRI - Université
> Bordeaux
> Dr. Sangeeth Simon,
> Team CAGIRE, INRIA,
> [8]http://www.labri.fr/~furmento/ LaBRI - Université Bordeaux
> Dr. Sangeeth Simon,
> Team CAGIRE, INRIA,
> References:
> [1] mailto:nathalie.furmento@labri.fr
> [2] mailto:nathalie.furmento@labri.fr
> [3]
> https://files.inria.fr/starpu/testing/master/doc/html/CheckListWhenPerformanceAreNotThere.html#CheckTaskSize
> [4] https://files.inria.fr/starpu/
> [5]
> [6] http://www.labri.fr/~furmento/
> [7] http://www.labri.fr/~furmento/
> [8] http://www.labri.fr/~furmento/
Samuel
<N> sl - display animations aimed to correct users who accidentally enter
<N> sl instead of ls.
- [starpu-devel] Problem in running task size overhead benchmark in starpu, Sangeeth Simon, 08/07/2021
- Re: [starpu-devel] Problem in running task size overhead benchmark in starpu, Nathalie Furmento, 08/07/2021
- Re: [starpu-devel] Problem in running task size overhead benchmark in starpu, Sangeeth Simon, 09/07/2021
- Re: [starpu-devel] Problem in running task size overhead benchmark in starpu, Samuel Thibault, 09/07/2021
- Re: [starpu-devel] Problem in running task size overhead benchmark in starpu, Nathalie Furmento, 09/07/2021
