coq-club - Re: [Coq-Club] Why do we have "Prop < Set" ? Why not just "Prop ≤ Set" ?
  • From: Matej Kosik <5764c029b688c1c0d24a2e97cd764f AT gmail.com>
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Why do we have "Prop < Set" ? Why not just "Prop ≤ Set" ?
  • Date: Thu, 19 Jan 2017 11:42:34 +0100
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=5764c029b688c1c0d24a2e97cd764f AT gmail.com; spf=Pass smtp.mailfrom=5764c029b688c1c0d24a2e97cd764f AT gmail.com; spf=None smtp.helo=postmaster AT mail-lf0-f54.google.com
  • Ironport-phdr: 9a23:meIrwxNmjdh8fKcEJFMl6mtUPXoX/o7sNwtQ0KIMzox0K/X7rarrMEGX3/hxlliBBdydsKMYzbaP+PixESxYuNDa7yBEKMQNHzY+yuwo3CUYSPafDkP6KPO4JwcbJ+9lEGFfwnegLEJOE9z/bVCB6le77DoVBwmtfVEtfre9ScbuiJG80Pn38JnOaS1JgiC8aPV8NkaYtwLU4+wfnYZgYoU20RrK6i8VJLoKzjsydFjNz0b3v8zo8MQ/+n5d6q0q+5EeDavScKExTLgeBzMjZTNmrPb3vAXOGFPcrkAXVX8bx0JF
On 01/18/2017 05:56 PM, Théo Zimmermann wrote:
> In fact, having Prop < Set, or Prop <= Set as a universe constraint does
> not force Prop : Set.
> And indeed:
> Coq < Set Printing Universes.
> Coq < Check Prop.
> Prop
> : Type@{Set+1}
> Coq < Check Set.
> Set
> : Type@{Set+1}
> That is Prop and Set both are at bottom of the type hierarchy: there are
> just two distinct bottoms.
Well, if you claim "Prop < Set", how can you say that "Set" is at the bottom
of the type hierarchy?
(we are back to the question: "What does _ < _ mean to you?")
> One of them is predicative:
> Coq < Check (forall P : Prop, P).
> forall P : Prop, P
> : Prop
> And one is impredicative:
> Coq < Check (forall P : Set, P).
> forall P : Set, P
> : Type@{Set+1}
(I guess that you wanted to say "Prop is impredicative" and "Set is
predicative".)
I am not sure if I understand why would these (desirable) properties prevent
us from relaxing "Prop < Set" to "Prop ≤ Set".
> Le mer. 18 janv. 2017 à 17:36, Théo Zimmermann
> <theo.zimmi AT gmail.com
> <mailto:theo.zimmi AT gmail.com>>
> a écrit :
> Hi,
> Disclaimer: there are people so much more qualified than me on this
> list who can answer this question. But as they did not wake up yet (maybe
> they are too engrossed in some POPL presentations) I
> will try to give a few hints.
> My personal, very limited, understanding of the universes was also that
> Prop : Set : Type 1 : Type 2 : ...
> But actually Check Prop : Set. fails both in Coq 8.6 and in your
> branch. I am not sure I understand why.
> Coq < Check Prop:Set.
> Error:
> The term "Prop" has type "Type" while it is expected to have type "Set".
> However, we can see that the constraint allows one to give type Set to
> something of type Prop:
> Coq < Check False : Prop.
> False : Prop
> : Prop
> Coq < Check False : Set.
> False : Set
> : Set
> As for weakening the constraint to Prop <= Set do you have any reasons
> in mind? This kind of weakening should allow in particular a constraint
> resolution where Prop = Set. But Prop and Set are
> supposed to be different! Because one is predicative and the other is
> impredicative. And also to help with extraction.
> However, even in your branch where you are supposed to have relaxed the
> constraint, it seems that there is still something preventing Set and Prop
> to be considered equal:
> Coq < Check nat : Prop.
> > Check nat : Prop.
> Error:
> The term "nat" has type "Set" while it is expected to have type
> "Prop" (universe inconsistency).
> Théo
> Le mer. 18 janv. 2017 à 17:20, Matej Kosik
> <mailto:5764c029b688c1c0d24a2e97cd764f AT gmail.com>>
> a écrit :
> Hi,
> On 01/18/2017 05:10 PM, Abhishek Anand wrote:
> > Going by the general rule that Ui:Uj if i<j, I suspect that Prop
> < Set would allow the following:
> > Check (Prop:Set)
> > which fails in Coq 8.5pl3.
> AFAIK this:
> Check Prop:Set.
> in all versions of Coq (8.5, 8.6, trunk).
> That makes sense.
> And precisely for that, the current version of the constraint:
> Prop < Set
> does not make sense (to me).
> > So the stronger constraint may allow some new well-typed terms
> and potentially complicate arguments about normalization/consistency etc.
> > -- Abhishek
> > http://www.cs.cornell.edu/~aa755/
> <http://www.cs.cornell.edu/~aa755/>
> > On Wed, Jan 18, 2017 at 9:27 AM, Matej Kosik
> <mailto:5764c029b688c1c0d24a2e97cd764f AT gmail.com>>>
> wrote:
> > Hi,
> > I have noticed that in Coq, we have the following universe
> constraint:
> > Prop < Set
> > I am wondering what is the reason for that?
> > Wouldn't
> > Prop <= Set
> > suffice in this case?
> > The code that makes the decision is here:
> > https://github.com/coq/coq/blob/trunk/kernel/uGraph.ml#L716
> <https://github.com/coq/coq/blob/trunk/kernel/uGraph.ml#L716>
> > I wonder whether it is necessary to do:
> > enforce_univ_lt Level.prop Level.set empty
> > as now, or we could simply do
> > enforce_univ_leq Level.prop Level.set empty
> > I've created an experimental branch where I did the change:
> https://github.com/matej-kosik/coq/commit/2fcbb0ced3bc32210ae9fbf4acc40804841c9200
> <https://github.com/matej-kosik/coq/commit/2fcbb0ced3bc32210ae9fbf4acc40804841c9200>
> > ran some tests:
> https://ci.inria.fr/coq/view/coq-contribs/job/coq-contribs/653/console
> <https://ci.inria.fr/coq/view/coq-contribs/job/coq-contribs/653/console>
> https://ci.inria.fr/coq/view/opam/job/opam-install/22/console
> <https://ci.inria.fr/coq/view/opam/job/opam-install/22/console>
> > and I do not see any breakage but the major question is,
> would this kind of change make Coq inconsistent
> > (enable us to prove False)
> > or not?
> > Thank you in advance for any insight on this.
> > Matej Košík
> Matej Košík
Matej Košík
